I have a 87.8 dB/1W sub. What is the equivalent dB for 2.83 Volts?
Thanks |
#2 |
That depends on the impedance of the sub. In general, every time you half the impedance you gain 6db. So the 4ohm would be 93.8db at 2.83v.
Dan |
#3 | |
2.83 V = 1W @ 8 Ohm; 2.83 V = 2W @ 4 Ohm; 2.83 V = 4W @ 2 Ohm etc. When you double the number of Watts, SPL increases with 3 dB. So if your sub has a SPL of 87.8 dB @ 1W and it's impedance is 8 Ohms, then SPL @ 2.83 V (= 1W @ 8 Ohm) = 87.8 dB If the impedance is 4 Ohms, then the SPL @ 2.83 V (= 2W @ 4 Ohm) = 87.8 + 3 = 90.8 dB (half the impedance means the double of watts at a given voltage level, so +3dB) |
#4 |
As I posted at Parts Express to your question there:
Many manufacturers dB/W values are actually 2.83V ratings. Since not all manufacturers rate them the same way, the only good way (short of actually measuring them yourself) to do this comparison is to do a apple/apples comparison using calculated (not rated) values. calculate dB/W as: dB1=112+10*log10(9.614e-10*Fs^3*Vas/Qes) Calculate dB/2.83V as: dB2=dB1+10*log10(8/Re) Vas in liters Re is DC resistance of coil, not the rated ohms.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#5 |
Why not use something like Unibox?
| Page generated in 0.09101 seconds (62.45% PHP - 37.55% MySQL) with 9 queries |
