Old 26th March 2006, 02:37 AM   #1
Default Wiring question
Hello all:
I have a 4 ohm tweeter and midrange. I have 4 seven inch, 8 ohm woofers I would like to use in a cabinet with the mid and tweeter. I know that if I wire two of the woofers in parallel, they become 4 ohm as a pair. Here is my question: Regarding cabinet design, if I put the mid and tweeter in the middle of a cabinet and two woofers above them and two below them, and I parallel each pair of woofers, will all of the woofers work out to be 4 ohms?
Another question now that I think of it: If the mid and the tweeter have a spl around 89 and the woofers have an spl at 85, will mating 4 woofers with the mid and tweeter throw the sensitivities out of whack?
Thanks,
Old 26th March 2006, 04:31 AM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
yes if you use 2 parralel 8 ohm woofers per cabinet the overall impedence of your system is 4ohms.
since the mid and tweet are more efficient they will sound louder. The pair of woofers in each cabinet will see .5w per speaker and you will gain ~+3db from running both per cabinet. so I would expect you to need ~-1dB on both the mid and tweet as a starting point. If your going to filter passive(after the amp) look at buying/building Lpads for seperate volume controls.
Old 26th March 2006, 10:39 AM   #3
lndm is offline lndm  Australia
Did you say you'd put all four woofers in parallel or pairs in series and the series pairs in parallel with each other?
Putting four in parallel gives an impedance of 2 ohms and a theoretical SPL increase of 12dB, giving 97dB/W/m.
With the series/parallel combo, the impedance would be 8 ohms and the theoretical SPL increase would be 6dB giving 91dB/W/m.
Due to line array effects, the SPLs may be a few dB lower than I have noted.
Old 26th March 2006, 11:20 AM   #4
you only need two 8ohm woofers to match each mid and treble combination.
The sensitivity of the 2 parallel woofers will be about the same as the mid and treble and you may find that they sound OK without correcting the upper speakers.
I would keep the woofers low in the cabinet. Keeping the mid and treble at ear level. What are you proposed crossover frequencies?
regards Andrew T.
Old 26th March 2006, 04:46 PM   #5
My cross point just off the top of my head would be around 500 and 5000.
On/off LED wiring question gary h Tubes / Valves 16 22nd June 2009 09:20 PM
DVC Wiring Question 69stingray Multi-Way 3 6th April 2007 01:42 PM
Amp/Sub Wiring Question OKCMustangGT Car Audio 3 31st August 2006 10:14 AM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 11:10 PM
Another wiring question. Prof Chip Amps 1 3rd July 2003 08:39 AM
Page generated in 0.08919 seconds (75.85% PHP - 24.15% MySQL) with 10 queries
