Old 24th March 2006, 05:05 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default Music modulation with 20Hz effects
I have a DIY 3-way speaker system and a "gainclone" DIY amplifier.
The amp has no capacitors at its input.
Today i tried to mudulate a music signal with 20Hz sinewave.I used
spectraPLUS as a generator and Windows Media player as a sound player.The output was set at moderate listening level. The sound changed A LOT when a 20Hz signal was applied.It was quiter and more distorted.
How could this be explained ?
Note that other tones , like 30Hz , does the same effect.
Lukas.
Old 24th March 2006, 07:11 PM   #2
What you were hearing is an extreme case of doppler distortion (someone correct me if i'm wrong here). I tried that once when i ran music through a 6in woofer and then modulated with a 20hz tone. At 30hz the cone movement is probably not even to facilliate doppler distortion. The sound is like talking into a fan.
Old 24th March 2006, 08:06 PM   #3
Another test i did was to set 1Hz tone ... The cone was moving without sound.Then i played some music ... The music volume was modulated by cone movement.I think it might be caused by loadspeakers , which have non-linear magnetic field and mechanical force ...
Old 24th March 2006, 10:24 PM   #4
maxro is offline maxro  Canada
maxro's Avatar
Actually, it's intermodular distortion (IMD). Doppler distortion is from a moving sound source, ie a train's whistle sounds higher pitched when approaching than when moving away from you.
Max
Old 24th March 2006, 11:27 PM   #5
pinkmouse's Avatar
Personally I would have thought it would be more likely that the PSU can't cope with the demands put on it, or the two superimposed waves are driving the amp into clipping.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 24th March 2006, 11:36 PM   #6
darkfenriz's Avatar
modulation
You mean you modulated envelope (AM) or multiplied with 20 Hz (DSB-SC)? Or just added and played together?
Old 25th March 2006, 08:28 AM   #7
I simply played together. PSU cannot be the cause , because volume levels were low.
Lukas.
Old 25th March 2006, 09:10 AM   #8
the sound volume level may have been low but the voltage drive to the speaker could be very high.
You just could not hear the 1Hz or 20Hz tone.
The normal music signal would be riding on the low frequency waveform.
I support Pinks thought. Clipping or severe PSU rail droop.
regards Andrew T.
Old 25th March 2006, 10:08 AM   #9
You were right - at even lower listening levels , the effect does not show up.However , distortion increase can be heard - probably showing that loadspeakers suffer from high IMD.
About the doppler effect - there is an article : http://sound.westhost.com/doppler.htm
Old 25th March 2006, 12:58 PM   #10
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Possibly larger cone area with lower travel provides less doppler effects. I also think one should not just consider music effects just by simple signals alone. When we hear bass, we listen in terms of relationship between the initial transient and the continued resonance to determine how realistic sound is produced.
Hear the real thing!
I got your 20Hz-20Khz Right here !!!! sumsound Multi-Way 21 19th August 2008 07:45 PM
Try to tune it to 18-20hz soloxp Subwoofers 11 17th March 2006 04:21 AM
20hz-20Khz Solid Snake Multi-Way 18 4th February 2004 07:08 PM
using ML TQWT ,20hz jbl mikee12345 Multi-Way 20 2nd July 2003 01:09 AM
Page generated in 0.10056 seconds (81.97% PHP - 18.03% MySQL) with 10 queries
