In order to accomodate long port tubes in a narrow and tall enclosure, can the port tubes be curved through 90 degrees? If possible, then what sort of correction has to be applied to the length of the port?
#2 |
Just use a PVC pipe elbow and the use the mean length (on the centreline of the elbow) in the total port length.
No longer DIY active |
#3 |
It should be a long sweep elbow like used for drainage, not a sharp elbow, which would cause turbulence, reduced output, and noise.
Check out lectrical conduit elbows. Don't forget about radiusing the corners, which you could do by making an MDF end flange and using a roundover router bit.
----------------------------------------- Noah |
#4 |
Thanks guys. I'll give it a try.
| Tubes that have round/curved plates. . . | Nihilist | Tubes / Valves | 17 | 24th June 2009 10:00 PM |
| Slot port vs circular port equivalence | Brisso57 | Multi-Way | 12 | 21st February 2009 02:38 PM |
| Single Port Vent Better than Dual Port? | Daveis | Multi-Way | 18 | 15th July 2007 05:12 AM |
| newbie question.WinISD and port tubes | PTM | Multi-Way | 4 | 31st January 2005 08:55 AM |
| To port or not to port? Newbie with newly built mains | starquake | Multi-Way | 1 | 18th December 2004 12:51 PM |
| Page generated in 0.08347 seconds (75.76% PHP - 24.24% MySQL) with 10 queries |
