#21 |
Cal:
I knew my sleuthing would give you a bit of a chuckle. I also suspect I was not too far from the mark with the chain of logic it portraited. If I may, I suggest you forego the belt sander in favour of the 6 inch random orbital variable speed PSA sander. I have a couple of them and they are the gift to non linear woodworking. It allows you to work in multiple planes and make smooth transitions. The random action means it is a non directional cutter so you do not need to worry about going accross grain, the variable speed allows you to adjust for cuttng diferent material types. I used mine on the hull of a canoe project and it turned out incredibly well. I do not think a belt sander would have come close. For the side panels you may want to add contour layers to the sides so you can have a completely non linear project. The other insipration I thought you may have had was from a Vino Pisco bottle, but that is way to cultured for you. OR it could have been Sonia's idea that you are plagiarizing. Hmmmmmmmmmmmmmmmmmm the mistery continues.................
SCD |
#22 |
Cal,
You may want to speak with the King... www.katools.com The King Arthur tools lancelot and squire on a small grinder are an incredibly fast and fun way to do your roughing in. Of course read and abide by all the safety requirements. I wear welding gloves, face shield, safety glasses, dust mask, long sleeves, hearing protection... You get the picture. Two hands on the tool at all times and clamped down workpiece. Be careful not to cut into the endgrain of the ply (tearout) Otherwise, these are a joy to use and can cut down on your belt sanding time significantly, especially if you move onto the big ones. As an added bonus, you can carve those scales...
Hugh |
#23 |
Speakerholic
This is getting fun. The cabinets are together and ready for final sanding before paint. I'm impatient so I put the drivers in for a listen.
The sound is pretty good. Those drivers sound bigger than they are. So far running the WR's straight and a 1 mfd cap on the tweet. Light stuffing. Think I will add more and maybe add a coil to the woofs. I'm still at Sonia's but I do have my camera and will post the pics soon. They don't look quite like fish or beer bottles but I think I'll use the inside part of the cut out and recut them to look like fish and decorate a big ugly wall at the back of the property. Reduce Reuse Recycle |
#24 |
Speakerholic
Should have read your posts before I answered.
It seemed to go fine with the belt sander, after I couldn't find a spindle sander that is. Great day for sanding, got the stuff spread around quite nicely, including places you should never find dust. Oh well, a half tank of hot water later I was good as new. ToE, Thanks for the advice, I never mess with safety. I'm happy to wear full gear even for a small job, including the custom ear "oysters" to preserve my critical analysis devices. |
#25 |
Speakerholic
Picture 1 of 6
It started with cut out of "fish" |
#26 |
Speakerholic
Cut out the center in a wiggly random pattern
#27 |
Speakerholic
Stacked and screwed with lots 'o' glue
#28 |
Speakerholic
Random pattern up close
#29 |
Speakerholic
Sand and check for eveness. Pencil marks are where fill is needed
#30 |
Speakerholic
Filled, ready for sanding.
| laminating Hedlund Horns | KMMM | Full Range | 10 | 18th December 2007 11:30 PM |
| Opinion on laminating front baffle | InfinityPWS | Multi-Way | 6 | 26th March 2006 10:30 PM |
| laminating glass | tade | Everything Else | 8 | 4th March 2006 07:56 PM |
| Platter Laminating...Best Adhesive? | valveitude | Analogue Source | 10 | 3rd November 2005 01:40 AM |
| methods for sealing/finishing mdf other than laminating? | lunchmoney | Multi-Way | 18 | 12th April 2005 06:01 PM |
| Page generated in 0.09933 seconds (83.10% PHP - 16.90% MySQL) with 11 queries |
