Old 21st March 2006, 10:45 PM   #1
lolojr1 is offline lolojr1  United States
Send a message via AIM to lolojr1 Send a message via Yahoo to lolojr1
Default open baffle and/or line array
hi i have my new speakers to start a new project.
72 2x3" woofefrs
i seem to be having trouble finding info on the subject can someone post some links or good keywords to search for the following speaker designs and or pics theory
i have searched on here and cant sem to find what i want
open baffle design, other than likwitz lab or o.b. sub stuff because that seems to be all i find
and line array stuff
thanks
Old 21st March 2006, 11:38 PM   #2
ScottG is offline ScottG  United States
http://www.partsexpress.com/projects.../Kuze3201.html
http://www.geocities.com/dmitrynizh/labaffles.htm
perspective is everything
Old 21st March 2006, 11:53 PM   #3
Dumbass is offline Dumbass  British Antarctic Territory
Jim Griffin's Near-Field Line Array Whitepaper (the nflawp) is required reading.
http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
With CTC of 2", you get comb-filtering issues starting around 5,000 (?) Hz. The typical solution would be to cross to one or more tweeter(s).
Old 22nd March 2006, 12:08 AM   #4
true, but with the partsexpress link you actually get to see what is happening with a 2" (vertical inch) driver, (rather than read some of the theory behind it). Both comb filtering AND midband gain ..and you can see that the midband gain is a BIT more important.
BTW, his comments on treble quality are probably NOT related to combfiltering, but rather primarily due to off-axis behaviour (which is no doubt lower in level).
Old 22nd March 2006, 12:40 AM   #5
I agree that there is interesting stuff to see. And the building techniques are cute. But all in all, I find it pretty half-assed, he just slaps in the drivers, doesn't even bother to power-taper them (despite how simple and proven effective it is), then uses a DSP to EQ it all flat.
There are much better thought-out projects out there.
Old 22nd March 2006, 12:48 AM   #6
Oh yeah! ..crap design, but hey - it was for his science class ..considering a teacher's salary and budget, how noble is that?
I use it as a link to effectivly say that "these" are the major problems that need to be addressed. In fact I haven't found any other graphical representation that depicts the rising midband problem.
The open baffle line array is the only DIY that I know of.. again another design I wouldn't personally use (..and thats puting it kindly).
Old 22nd March 2006, 01:59 AM   #7
ive seen all those links and they are nice verry informative
i was curious about power tapering and not sure i was going to do it howmuch does it realy effect final output (spl) i cant imagine that these little spakers are going to handle tons of power
Old 7th July 2006, 02:36 AM   #8
just bringing this to the top hoping to find more info if possible?
Old 7th July 2006, 04:47 AM   #9
ppfred is offline ppfred  Canada
Default Re: open baffle and/or line array
http://audioroundtable.com/ArraySpeakers/
http://ldsg.snippets.org/ALSR/index.php3
http://yu-ra.tripod.com/array.htm
http://www.svconline.com/mag/avinsta...t_line_arrays/
http://home.earthlink.net/~jmiyake/index.html
http://www.rawacoustics.com/
http://www.selahaudio.com/id103.html
http://www.roger-russell.com/xrt20.htm
http://www.lonesaguaro.com/speakers/array/array.htm
This should keep you busy.
I especially like this one:
and this one:
fred p.
Believe nothing you read and only half of what you see.
Open Baffle Line Array 24kilo Multi-Way 11 24th September 2005 04:10 AM
line array open baffle spkerguy Multi-Way 5 6th January 2004 08:42 AM
Open baffle line array ryoshu Multi-Way 15 15th January 2003 11:10 AM
Page generated in 0.10814 seconds (81.15% PHP - 18.85% MySQL) with 10 queries
