Kef reference 104/2 circuit diagram
Old 22nd March 2006, 11:07 PM   #21
clem_o is offline clem_o  Philippines
LF (coupled cavity) enclosure, with the HF/MF module removed:
Old 22nd March 2006, 11:08 PM   #22
HF/MF enclosure, back portion. All sealed, save for the HF unit, fairly easy to remove - loosen screw, slide wooden block, lift tweeter out.
Old 22nd March 2006, 11:10 PM   #23
One and only crossover, mounted on bottom "cover" of the LF enclosure (where the spiked feet are mounted). I can post the bottom (trace) view of this board, if anyone is interested...
Left side: inputs to the crossover (biwired inputs)
Right side: outputs to LF drivers
Bottom: connections still visible to the multiwire royal cord connecting to the HF/MF enclosure..
Old 1st December 2006, 07:06 PM   #24
zachnny is offline zachnny  United States
I have KEF 103/4's (vintage 1992), and need to replace the Uni-Q driver in one of them. Unfortunately, I dissassembled the driver without noting which internal wires went to which posts on the driver. Does anyone happen to know the wiring schema for the Uni-Q driver. I need to know where the yellow, green, brown, and blue wires coming from the crossover connect to the mid-range and tweeter posts on the actual driver. Thanks!
Old 1st December 2006, 07:51 PM   #25
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Look in the other speaker?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 8th December 2006, 10:23 PM   #26
AndrewJ is offline AndrewJ
The KEF wiring scheme used the following colours:
Blue: HF+
Brown HF-
Yellow MF-
Green MF+
Hope this helps
Andrew
Kef reference 104/2 circuit diagramHide this!Advertise here!
Circuit diagram for Trilogy VTi. harwoodspark Tubes / Valves 0 1st August 2007 06:36 PM
Circuit Diagram epacor Parts 1 3rd February 2007 06:42 AM
Help! circuit diagram vodaTube Tubes / Valves 0 8th July 2005 06:49 AM
ML 383 circuit diagram leigong Solid State 0 29th June 2004 02:13 PM
