Hi!
I saw them, but unfortunately not listened yet! They are fascinating!! I know only some data: "Bösendorfer's largest floor standing loudspeaker. Two-way system with two treble speakers, four bass drivers /mid-range speakers and two Acoustic Sound Boards. frequency response 25 - 27,000 Hz ( ±3 dB) crossover frequencies 130 Hz*; 2.5 kHz power rating 180 watts music rating 360 watts impedance 4 ohms operating performance 1.1 watts (for 91 dB/m) dimensions (h x d x w) 1330 x 403 x 195 mm (52.4" x 15.9" x 7.7") weight 36.5 kg (80 lbs) * based on the performance of the HornResonator" www.boesendorfer.com Has somebody any idea how this loudspeaker works?? Tyimo |
#2 |
There is no truth. Only incomplete perception... |
#3 |
Hi Redunzelizer!
Thanks a lot! There is very good infos!!!!! A must read! greets: Tyimo |
#4 |
From what i understand they can only reproduce piano music. And preferably played on a Bösendorfer piano. That's what people with taste listen to anyway
#5 |
I've heard them on the Hifi fair. They impressed me as you get really good sound anywhere in the room. In the sweet spot they were a bit bright.
The concept is basically side firing midrange drivers. That gives the speaker its character. That concept has some drawbacks in regards of neutral sound reproduction. Stephan |
#6 | |
Hi Stephan!
Look at that "Acoustic Sound Boards" and the "HornResonator" theory. Tyimo |
#7 | |
Stephan |
#8 | ||
Hi Stephan!
Could you "translate" the HornResonator theory too? Tyimo |
#9 | ||
Hi Tyimo,
Stephan |
#10 |
I would also search for the Tornado, a DIY concept that also works with sound board resonators.
| DIY loudspeaker vs. factory built loudspeaker | keyser | Multi-Way | 83 | 16th May 2011 12:27 PM |
| BBC LS S/5 loudspeaker | Tyimo | Multi-Way | 11 | 16th August 2007 05:38 PM |
| Loudspeaker for T-amp | ecodoppler | Multi-Way | 2 | 14th October 2005 11:15 PM |
| Loudspeaker POP - How to Fix- | Aural Dan | Everything Else | 7 | 13th December 2004 09:49 PM |
| Please help with my diy loudspeaker | khorne | Multi-Way | 3 | 8th April 2003 08:38 AM |
| Page generated in 0.10957 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
