Rene Christensen has published "Active All-Pass Crossover Networks with Equal Resistors and Equal Capacitors" in the Journal of the Audio Engineering Society (Jan/Feb 2006) -- better group delay characteristic compared to LR.
#2 |
Sounds interesting.
Could you post a schematic or any other details if possible. Thanks |
#3 |
WHOA?!?!? Really? I definitely must have overlooked that issue. If I find it I can scan her in.
ERTW 4 life! "the day has 24hours. If that is not enough take the night."-Roemhild |
#4 | |
#5 |
maybe my question is a bit early, but are we talking about a crossover or a phase/time delay circuit?
regards Andrew T. |
#6 | |
Fun aside: It is an active crossover that trades slightly improved phase-characteristics against less steep amplitude response. The initial rolloff rates of the high- and lowpass are quite shallow. Regards Charles |
#7 |
an ALL-pass does not operate as a crossover. It passes all frequencies upto it design roll off which is usually chosen to be beyond your chosen range of use. Further the ALL-pass is a low pass stage. There's where my question comes from.
regards Andrew T. |
#8 | |
I guess the clue is the wording of the article "Active All-Pass Crossover Networks" It is rather confusing to convention wisdom on the subject. All pass says to me; delays and shelves. Whilst crossover networks suggests high, low and bandpass. Perhaps this is an all pass network that simply is part of a 'crossover' network? |
#9 | |
Found a little bit:
http://www.aes.org/journal/toc/AES-JanFeb2006TOC.cfm Looks to be a crossover filter from the description. |
#10 |
All capacitors and resistors the same hey. That's easy, just use the state variable Linkwitz-Riley design as described by the Rane Corporation here http://www.rane.com/pdf/linriley.pdf
Features: Fewer resistors and caps if you want to make an adjustable crossover. Less opamps than say the Rod Elliot Linkwitz-Riley. High and low outputs from a single "stage" that have identical crossover frequencies. Again nice for an adjustable. I have only just started to think about active crossovers but I don't see what the problem with phase might be with this. High and low outputs are in phase to withing few milli degrees at all frequencies. So far I have simulated and built the low and mid section as in the attched schematic.
For me the past is not over yet. |
| Linkwitz-Riley Crossover questions | MBrej | Solid State | 2 | 15th January 2009 12:19 PM |
| Linkwitz Riley Filter Implementation | Roysyboy | Subwoofers | 1 | 19th September 2005 03:40 AM |
| Group Buy: Linkwitz-Riley 24db/oct xover PCB's | substrate | Group Buys | 21 | 10th March 2005 11:44 PM |
| Linkwitz-Riley Cross over question | rs1026 | Chip Amps | 2 | 27th August 2004 09:15 PM |
| linkwitz-riley crossover | arthur | Solid State | 0 | 28th April 2003 10:26 AM |
| Page generated in 0.12635 seconds (76.72% PHP - 23.28% MySQL) with 11 queries |
