Old 12th March 2006, 03:28 PM   #1
graks is offline graks  Norway
Send a message via MSN to graks
Default Check my Odin X-over...
I have buildt the Seas Odin kit, but the tweeters are very loud. Could you x-over experts check the x-over? I use Electrocompaniet AW220 for the tweeters, and another AW220 for the W18 elements. Since i have biamped i now have lowered the signal to the tweeters x-over from the amp, but it would be best if i didnt have to. The schematic are here: http://www.seas.no/kit/FILTER_THOR_ODIN.pdf
Old 12th March 2006, 03:31 PM   #2
The x-over for the woofers.
Old 13th March 2006, 02:54 AM   #3
sidiy is offline sidiy  Canada
sidiy's Avatar
Default X-over looks fine
Hello,
Do you use a (very) short connection between PA and Xover? If so try connecting a series resistor with L3. It has to be a small value... about 0R22 will work. (well, it did for me... )
Pading the tweeter further down by increasing R2 would be my second option....but you can combine the two methods...
Good luck
Old 13th March 2006, 06:57 AM   #4
I use aprox. 1 meter cables between PowerAmp and Xover, it is Supra Ply 3.4/s.
Old 13th March 2006, 09:31 AM   #5
kimbo is offline kimbo  Australia
kimbo's Avatar
Graks, are you using identical amps for both tweeters and low speakers? If not you will probably find that they don't have identical gain. In fact it would be unusual for them to have identical gain (and input resistance).
In my biamped system I drive the tweeters via my NAD receivers main amp (25W) and the bass via a home made 55W/ch amp. I had to add a twin pot to the crossover output high output so I could reduce the level of the tweeter to match the drivers. It now sounds pretty good. (I may replace the pot with a 'L' pad using 1% resistors at a later date to reduce noise once I am confident that the level is correct)
Cheers, Kimo
Old 13th March 2006, 10:21 AM   #6
I have identical amps for the woofer and the tweeter, both are EC AW220 . On the amp for the tweeter i have reduced the gain since they have adjustable output gain.
Seas Odin MK3 carl1009 Multi-Way 0 23rd March 2009 05:48 AM
Odin mk3 for center channel? BrianGT Multi-Way 14 27th May 2008 05:30 PM
Any Froy or Odin owners? weinstro Multi-Way 19 4th March 2006 09:33 PM
thor vs odin MikeZ Multi-Way 55 9th December 2004 04:00 PM
Very curious - Two types of Odin SuppersReady Multi-Way 1 16th November 2003 02:45 PM
Page generated in 0.06827 seconds (84.78% PHP - 15.22% MySQL) with 11 queries
