I have a visual design concept for a loudspeaker, but I do not know if it would sound good. Would someone please briefly explain how does a sealed enclosure serve to extend the bass response of a driver? How is the optimal enclosure volume of a driver predicted or calculated? Why is the recommended sealed enclosure volume for a driver usually less than the ported volume? What would happen if 2 cone drivers were mounted in-phase in a sealed enclosure with significantly less volume than the recommended volume? Thank you.
#2 |
#3 |
Speakerholic
This is a link to help design your box. If you have the T/S parameters just plug them in.
http://www.mhsoft.nl/spk_calc.asp Most of your questions will be answered as you go through, it's a great site. Everytime you double up the drivers you have to double the volume as well. If your box is too small, the box doesn't allow the drivers to "breath" enough and the depth of bass is compromised. It actually gets quite complicated the further you delve into it but sites like that seem to ease the pain a bit. |
#4 | |||
The cabinet separates the front from back. Quote:
Primarily Vas, Fs, Qts Quote:
[quote]What would happen if 2 cone drivers were mounted in-phase in a sealed enclosure with significantly less volume than the recommended volume? /QUOTE] You'd get less bass. You'd get a response that peaks at a inconvenient place. It'd sound rather 'flabby' |
#5 |
Thank you for the helpful info! This will guide me in refining the concept.
| Preamp beginner questions, any help appreciated | gaplessophile | Chip Amps | 11 | 10th March 2006 09:56 PM |
| Some beginner questions... | flaevor | Class D | 12 | 5th August 2005 11:29 AM |
| ZEN V4 questions for beginner | hbarki | Pass Labs | 4 | 9th January 2004 11:25 PM |
| aleph 2 questions (beginner) | Luke | Pass Labs | 21 | 6th September 2002 12:59 PM |
| Beginner Has Some Questions...aleph | Steve Fay | Pass Labs | 40 | 13th May 2002 07:34 PM |
| Page generated in 0.09313 seconds (68.89% PHP - 31.11% MySQL) with 10 queries |
