Old 11th March 2006, 03:23 PM   #1
Default Upgrade cross over
I have some B&W 601 s3's and I had decided to try and do a diy set up for around 300 and start using those, but the folks here told me I should try to tweak what I have first. I figured I could give it a whirl and see if I can get the performance I want. I'm open to any suggestions but the first thing I thought I would give a try is to upgrade the cross over. Here's a pic
http://www.bwspeakers.com/images/pho...r_close_up.jpg
I've never done this before so if somebody could tell me what exactly to upgrade on it and how, that would be great. Thanks a bunch.
Bruce
Old 11th March 2006, 04:20 PM   #2
Speakerholic
Cal Weldon's Avatar
Hi Bruce,
I have moved this over to speakers and hopefully more will see it here.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 11th March 2006, 04:26 PM   #3
Thanks Bro.. I was just looking at it in confusion wondering how it was in Loudspeaker, and then I saw you post. I appreciate it.
Bruce
Old 12th March 2006, 12:05 AM   #4
lndm is offline lndm  Australia
Two possibilities spring to mind. One involves arranging the components so they are physically separated from each other, especially the inductors, and firmly held in place. Make sure they are far from the magnets, and connected with soldered joints.
The other is to upgrade the components. To be brief, ditch the sand cast resistors and don't use polyethylene capacitors here. Try non-inductive wirewound or carbon resistors IMO. Try polypropylene or paper capacitors IMO.
Using heavy gauge inductors and cables may help or hinder an existing design. Worth a try.
Old 12th March 2006, 01:42 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Did the people that suggest you modify the crossover suggest anything specific. I personally think there are diminishng returns going down that avenue. B&W has the talent and resources beyond the capabilities of most people here. Unless you consider yourself golden ears you prob cant distinguish between cap dielectrics. If you use beefier chokes you can actually spoil the intended Q of the design. I vote to leave them in stock condition and think about selling them if you are really unhappy.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 12th March 2006, 02:33 AM   #6
IMO the reason there is uncertainty over whether the sound of components matters, is where they are tried. ie. put a quality capacitor in a mass fi device and what difference do you notice.
When a system is almost top notch, the components can end up being the biggest problem, and much easier to notice.
Still, B&W components are probably OK already, but if you wan't to keep your existing setup, this is worth it.
Old 12th March 2006, 04:51 AM   #7
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Typically, for most designs the cost of the crossovers are more than the cost of the drivers. I recommend you try some cheap tweaks, but don't try to redo the entire crossover because that sounds risky. Basically if the cheap tweaks don't work, build a well-regarded DIY design. Then at least you know that the speakers are not the problem in your audio chain, it'll be something else (ie. the source or whatever). Saying that the speakers will not be the problem with a good DIY design is a bold statement, but in my experience it's true, these DIY speakers are really excellent.
Old 12th March 2006, 10:28 AM   #8
infinia's Avatar
First of all. You need to figure out what you believe are the problems with your B&W's, (i.e. not enough bass, quality of bass, missing resolution in the midrange, distortions in HF, on&on)
How can we help you solve a problem if you cannot articulate it?
You can spend loads of cash on aftermarket upgrades to a crossover. In the end, all for naught if it doesn't meet your expectations. Crossovers are the cash cow for most DIY speaker dealers. They take advantage of newer people to DIY. Let me say this, as a longtime designer if you are spending more on a crossover than a single driver, you have failed in your preliminary driver selection (period and exclamation point).
Old 12th March 2006, 02:46 PM   #9
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Listen to the system first and determine what you don't like about it.
Draw up a schematic to have a good idea how the current crossover looks.
Test the drivers on the inclosure individually to see how they perform.
Connect two by two in parallel to see how they might acoustically interfere with each other.
Measure the closed box impedance of the cone drivers.
Design XO and build as you normally would DIY to see how differently it sounds using the same quality of componenets. If the result is better, replace DIY XO with best components you plan to use and listen again.
Hear the real thing!
41Hz AMP2 upgrade... What parts to upgrade? MotoMan_Yz400 Class D 2 6th March 2008 05:28 AM
Muse Model 2 DAC upgrade with Guido Tent DAC upgrade? jpchleapas Digital Source 1 31st January 2008 07:18 PM
A cross between A5 and A3 Stabist Pass Labs 47 21st December 2004 05:27 AM
How do you cross over really low? Nappylady Multi-Way 7 25th June 2004 08:29 PM
No Cross Over! chris ma Multi-Way 27 3rd January 2003 01:53 AM
Page generated in 0.12708 seconds (79.48% PHP - 20.52% MySQL) with 10 queries
