Old 10th March 2006, 08:02 AM   #1
Default DIY Scan Speak three way speaker
Hi folks,
I'm still looking for a nice speaker, using scan speaks.
This one looks nice:
http://www.troelsgravesen.dk/Ekta.htm
The D2904/7000 tweeter is really much too expensive but anyway. To replace my current tweeter (Dynaudio Esotar 330D) I need a nice tweeter.
The mid 12M/4631-G00 is also one of my favorite and the 18W/8531-G00 looks also good.
I realy don't know, should I use a 12 or 15 or 18 cm mid in combination with the D2904/7000!?
Like here, using a 18 cm mid (Viper SP II R):
http://www.speakerheaven.de/
Here is a nice DiApolito system with a 15 cm mid/woofer (Studio 24):
http://www.aos-lautsprecher.de/
I listen close to 90% jazz and work with 50 watts from my tube power mono's with EL 34 tubes (Shanling ST-80 classic). So, there is not that much "power".
Is there any other idea?
Thanks in advance and best regards
Frank
Old 11th March 2006, 08:20 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Whats wrong with your setup you have now?
I thought Dynaudio Esotar 330D was one of the best?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 12th March 2006, 06:41 PM   #3
Hi infinia,
my current speaker is a modified Dynaudio Gemini. The tweeter is really good. But I miss a deep bass from this speaker (15W75) and I don't want to develop and built a new speaker with these speakers. I want something really new.
Old 12th March 2006, 08:05 PM   #4
David Gatti's Avatar
If you're building a 3 way, then it's preferable to use a true midrange, rather than a bass-mid. Hence the 12M or 15W would be the driver's of choice. However the 12M has 4 ohm impedance which may be a problem, so the 15W may be more suitable and would allow crossover to your tweeter anywhere from 2.5-5kHz.
As the 15W has good low end performance, a 10" bass driver can be used (eg 25W8565).
Old 13th March 2006, 12:49 AM   #5
LineSource's Avatar
For a Seas 3-way I lust after WMTMW with T25CF002 millennium tweeter, W15CY001 midrange and W26FX001. LR4 at 2.5K and 250 with sealed, equalized bass. The W15 will give better dispersion 30* off axis than W18, and allows a higher Xover point that seems to help female vocals. The W15s would have a separate, heavily stuffed enclosure.
Old 9th June 2006, 04:32 PM   #6
Hi Yoda
I am about to build a pair of AOS Studio 12XLs that use the scan-speak 7000 tweeter. It is a very highly regarded monitor that some say is the best available regardless of price. When I have finshed, I will build the Studio 120 bass unit, also from AOS. This will make a three way loudspeaker (as you wished) in two cabinets (one on top of the other). Very sweet, very flexible. Hard to beat.
These kits are available from AOS as well as the lautsprechershop
see http://www.lautsprechershop.de/ and click on the scanspeak loudspeaker kit section.
or, http://www.aos-lautsprecher.de/index.html
Good luck.
Dublin78
Old 10th June 2006, 12:04 AM   #7
IMHO, the Ekta is probably one of the nicest 3-way box designs freely available for DIYers.
If price is a concern, use the XT25 tweeter, with which Troels kindly provides a crossover modification.
The XT25 has very high performance, and you don't have to worry about substituting it for the SS Ring Radiator.
Old 10th June 2006, 01:17 AM   #8
Is now a good time to tell you that I'm in the process of building a pair of modified Ektas ?
Modified ?
No stupidly expensive 7000 tweeter for me.
will be using a 9500, Troels very kindly did a simulation crossover to use the 9500 for me.
He refuses to publish the changes though because as he says
"I will not publish something that is untested"
Which I commend him for.
Just got the timber from the carpenter last night.
So will be maybe a month or two away from being finished.
Only taken SEVEN months to source and aquire needed parts.
Old 11th June 2006, 05:08 AM   #9
rkreim is offline rkreim  Australia
i have built these and i am happy with them
http://hem.bredband.net/b227650/galtis/galtisstart.htm
Old 11th June 2006, 06:22 PM   #10
hi dublin 78,
yes, your AOS 12XL will be a really fine speaker. I already bought the 24XL. Great, near perfect!
Hope you will enjoy your 12XL!!!
Scan Speak 23W sub Pan Subwoofers 15 26th December 2007 06:13 PM
3-way Scan-Speak marvii Multi-Way 9 15th April 2007 04:14 PM
Scan Speak 15M Jed Multi-Way 27 23rd March 2007 07:45 AM
Creating a 3-way reference speaker Scan-speak caenot Multi-Way 22 15th December 2004 12:46 AM
Page generated in 0.10915 seconds (82.10% PHP - 17.90% MySQL) with 10 queries
