First of all i wish to say thanks to all of you that gave me info for places to go in Toronto.
I have had these drivers in my system for a while although I was not completely happy with them they sufficed. I am in the process of rebuilding them, I've got the enclosure completed but they seem a bit hollow to me in the upper midrange so I was wondering if any of y'all could help me? the 7w4411 parameters are: Fs = 39.5 HZ Qms = 7 Vas = 1.197cu. ft Xmax = 0.217 in Sd = 25.59 sq in Qes = 0.38 Re = =7.8 ohms Le = 0.69 Z = 8 ohms Pe = 90 watts TC 90Tdx Fs = 693.8 hz Qts = .63 Qes = .83 Qms = 2.72 Rcc = 6 ohms Zmax = 24.83 the enclosure is http://www.studio6r.com/Stereo/_PMD2333.jpg all sides top back and bottom .75 mdf front baffel 1.5 mdf port Id = 2" length = 6" w= 11.25 h=19.25 top depth= 8" bottom depth 11.5' attached current crossover pics http://www.studio6r.com/Stereo I have 4 of the 7w4411's and plan to try a mtm floor-stander ala Zalytrons Titanio Elite http://www.zalytron.com/audiophile.htm subbing the tc90tdx for the audiom TLR later when I decide on a wood and finish. I purchased all of these drivers and crosover components from Zalytron and i have an e-mail into them for help but I thought I would beg y'all for some advice as well. thanks in advance mdr ![]()
#2 |
Hollow upper midrange, as you descibe it, points in direction of fase problems - I would think 1mH is too big
By the way, have you reversed polarity on tweeter - it should be |
#3 |
(nt)
#4 |
I agree about the phase. No matter what information I find or try to calculate about a driver, nothing can beat measuring my own frequency phase plot for each driver in it's enclosure. With relative differences between the drivers being the larger issue, I have found my estimates to be way off sometimes.
Then you could use a crossover simulator to do the rest. About the 1mH inductor, if it seems larger than it could be, it is likely the correct value for the original design - compensating for baffle step diffraction. It will only work for the original box. If you measure your own frequency response, you should get excellent results. |
#5 |
I reversed the polarity of the tweeter, and it's much better!
As far as the crossover it;s self goes i;'m going to build the Titanio Elite http://www.zalytron.com/audiophile.htm this week and focus my efforts on that. thanks once again, I'll post pics and info when it's completed. mdr |
#6 |
I would suggest using some information from this design by Osborne Speakers
http://www.osbornloudspeakers.com.au...titanspec.html |
| Assistance required in rebuild of a focal crossover | soundengine355 | Multi-Way | 34 | 1st April 2009 12:05 AM |
| Focal 2-way crossover design options | focal7C | Multi-Way | 4 | 20th August 2008 02:56 AM |
| Focal Bookshelf - Audiom TLR & 7W4411 | Richy | Multi-Way | 6 | 31st July 2008 01:53 PM |
| Raven 2 + Focal 7W4411 2.5 Way? | mgreene | Multi-Way | 3 | 29th October 2007 04:37 PM |
| WTB: Focal 7w4411 | TurboFC3S | Swap Meet | 0 | 17th October 2006 06:48 PM |
| Page generated in 0.09579 seconds (74.98% PHP - 25.02% MySQL) with 10 queries |
