Old 8th March 2006, 08:51 PM   #1
Question inductance and Q question
I have a question relating my Ascendant Audio arsenal 12. with my old atlas 12 they recommended different shorting methods to the second coil depending on your application (for low, mid, or high Qts). what could i expect from shorting the second coil on my arsenal? lower inductance im assuming but what happens to the effective Qts (would it be cut in half, root of original, some other formula)? how would different value resistors affect them or would you actually recommend the use of a potentiometer? any suggestions? how would you calculate the Qtc for that sub in a ~1.3cf enclosure. is there a magic number we try and shoot for ever? and could one achieve the desired Qtc with a sub that requires a bigger enclosure in a small box using the potentiometer method? what would you use to measure it then?
Old 9th March 2006, 01:30 AM   #2
lndm is offline lndm  Australia
Vas/(((Qtc/Qts)^2)-1) gives box size. Invert this as required. Qtc=0.5 to 1 is common (horses for courses).
Try googling measure Qt for instructions.
Old 9th March 2006, 12:25 PM   #3
http://www.users.bigpond.com/bcollis...onversions.htm
and WinISDPro.
/sreten.
Old 9th March 2006, 04:28 PM   #4
thanks guys... is there a magic number u shoot for? i'm more interested in the shorting effect
Old 9th March 2006, 09:25 PM   #5
I am not familiar with this speaker, but decreasing the Q of the fundamental system resonance (if that's what you are asking about) sounds like a good idea if you feel the bass is too strong/loose. Such as when you need to put the unit close to a corner, or in a small room, or when you need to sit against a wall.
Old 10th March 2006, 01:41 PM   #6
infinia is offline infinia  United States
infinia's Avatar
Shorting the second voice coil on a DVC driver would act like a electric brake limiting VC movement. You would still get sound much lower levels esp for bass notes. Half power for high notes.
Not sure if this answers your Q.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 10th March 2006, 05:10 PM   #7
You might want to take a look at the DVC papers from Adire. Some handy explanations & variations:
http://www.adireaudio.com/TechInfo.htm
regards
Audio Transformer Inductance Question kelticwizard Everything Else 1 9th April 2007 05:28 AM
Who might be able to measure inductance? fazman Multi-Way 8 21st August 2006 12:26 PM
Inductance of big transformers??? Magura Pass Labs 1 28th October 2004 06:16 PM
can I use this cap? what about low inductance? Wagener Solid State 3 9th May 2004 10:54 AM
How to measure inductance? Jimmy154 Multi-Way 41 20th July 2003 03:37 AM
Page generated in 0.08029 seconds (76.84% PHP - 23.16% MySQL) with 10 queries
