My woofer's surround has some defects. It's somewhat like a white crust inside has developed. Not sure if it is a FUNGUS or RUST due to humid weather . The rubber surround is still perfect .. i mean no cuts or punctures., it's just that it is now peeling off since the crust seems to be growing. Have already ordered for a woofer replacement from the agent. It there any treatment to be applied on the woofer to prevent this to happen in the future ? I will also be sending the woofers for repair/re-glue. I would appreciate if you guys have experience on re-glued cones. Does the performance or sound quality degrades. I still plan to use it as a back-up since the magnet and the coil are still in perfect condition. Appreciate any informations that you can share. Here are some of the pictures..... by the way , the speaker is Sonus Faber Signum. ![]() ![]()
#2 |
I've never seen that sort of growth UNDER the surround.
Since they're rubber, they shouldn't be rotting, so my my guess is it's some sort of reaction to the metal and or glue. Are they kept in a humid environment? Have you spoken to SF about this? May be a warranty issue. Also, usually after a decent reconing, performance is as good as the original. |
#3 |
Thanks for the reply ..
My country is really humid. I've seen some fungus growing on the cone surface of my other speakers. Just a regular cleaning will do the job , but this is really extreme !!. The speaker is around 5 years old so i can't claim for the warranty. I've sent an email with pictures to the manufacturer but no response from them. SInce i've already ordered a replacement woofer, i'd better replace them and keep the the other pair as a spare. This morning, i removed the woofer from the cabinet and was SHOCK to see what is inside This is really serious !!! Is there any treat for this defect to prevent it from re-surfacing on my next NEW driver ?
#4 |
Speakerholic
When you wipe it off does the finish underneath look good still or is it somewhat pitted?
The reason I'm asking is that from the pictures, it is hard to tell mildew from oxidization. If it is oxidization there should be some signs of pitting. If not it's likely mildew. If it is mildew, them I recommend wiping it with a mild chlorine solution first and then try wiping the basket with penetrating lubricant and see if that slows it down or stops it. |
#5 |
Why is it only attacking the paint on the basket? I think this is an important clue. Whatever it is is not attacking the cone, or the magnet, or the pole pieces, or the surround. Looking more closely, the worst corrosion is where the airflow is the least (inside the ribs of the basket). That suggests that it's the paint releasing something horrible.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#6 |
Do you live near the sea? Looks like salt oxidation.
Best investment - an airconditioner. |
#7 | |
Thanks for the recommendation for the treatment |
#8 | |
#9 |
Are both bass-mids & the tweeters the same?
Another possibility is that some wiring is, or was, touching the frame causing rapid electronic oxidisation. Have you checked? |
#10 |
Yikes
Looks like the cast aluminium has become the anode from the steel/magnet motor part. Not sure how to prevent that, other than get something designed for marine applications. Probably best not to try to clean them unless you know what youre doing.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
| Proac/Seas woofer surround crack | banana | Multi-Way | 21 | 12th October 2011 08:17 AM |
| Yamaha NS-80 woofer foam surround | DragonMaster | Multi-Way | 5 | 11th March 2008 01:17 PM |
| Fungus 'amung us' | jackinnj | Analogue Source | 10 | 2nd April 2006 01:51 AM |
| Surround sound amp, Sub woofer and television | warrennyc | Subwoofers | 4 | 3rd January 2005 10:33 AM |
| CD rot and fungus | ashok | Everything Else | 2 | 31st March 2003 02:19 AM |
| Page generated in 0.11696 seconds (84.39% PHP - 15.61% MySQL) with 11 queries |
