Old 7th March 2006, 03:14 PM   #1
Guijs is offline Guijs  Brazil
Default Crossover recomendations/enclosure for SEAS W15CH001 and Hiquphon OWI?
Hello,
Does anyone have a xover point recomendation for the SEAS W15CH and the OWI? Would 3khz @ 12dB/8a be good? The CH has the cone breakup at 8khz, so it doesn't need a xover point as low as the W18E001. Any enclosure tips? WINISD says around 19L... What about a free-air/dipole configuration? I only worry about the sensibility of the SEAS, but the Qts 0,42 is a good value for open baffle, don't?
I want to build a bookshelf with this speakers (I already have them) just for tests, because i'm planning to buy the Dave Ellis kit www.ellisaudio.com . My amplification is a 30w EL34, Pentode Push-Pull amp, with Tube preamp using 6sn7's.
Thank you
Guilherme
Old 7th March 2006, 05:05 PM   #2
http://www.troelsgravesen.dk/W15_OWI.htm
/sreten.
Old 7th March 2006, 07:07 PM   #3
tf1216 is offline tf1216  United States
sreten,
I believe the 2-way Troels completed was with the W15CY.
Old 8th March 2006, 09:19 PM   #4
That is the CY... Does anyone know something about that bookshelf from a user in the forum, that uses the W15CH with JP2 Ribbon tweets?
Old 8th March 2006, 10:07 PM   #5
My apologies! I should have read the article closer.
I have only been to Troels site 1 million times, I should have remembered this speaker.
http://www.troelsgravesen.dk/W15.htm
Old 7th June 2006, 04:35 PM   #6
Hello,
Does anyone have a enclosure suggestion for the W15CH001?
Old 7th June 2006, 05:28 PM   #7
Originally posted by Guijs
Hello,
the only difference to the W15CY is higher Qts, 0.42 to 0.36.
The parameters indicate a sealed box of 7.5L to 10L is suitable.
/sreten.
Old 7th June 2006, 05:40 PM   #8
Notax is offline Notax  Montenegro
Notax's Avatar
Hello,
Didn"t work with. My calculations.
Bass-reflex.
Vb=10.2 liter netto
Fb=41.4 Hz
Dt=30 mm
Lt=115 mm
x-over. you must "catch it" really low, mid-bass with 6 dB at 600-650 Hz (-3 dB). Maybe RCL for resonant peak of the cone at 8 kHz. Because od that, you need tweeter that can go really low, about 1500-1600 Hz lowest. Some Scan-Speak or Seas 28 mm soft-dome. Tweeter with 12 or 18 dB/oct. at 2 kHz (- 3 dB).
If you go higher with cut-off freq. bass will be "tiny", because of higher SPL of the mids. Balans is everything.
Beauty and the curse of 2-ways.
Old 7th June 2006, 05:57 PM   #9
Hello,
Thanks for the help!
I'm using the speakers in a old enclosure that I have here. This enclosure is Bass Reflex, very simple (no internal bracing) with aprox 18L and 6cm L x 5cm D port lenght.
The sound is very good. Deep bass for a 5'' speaker, and very good middle and midbass. The crossover is 12dB/8a 2,5khz.
I'll build a decent enclosure (with bracing, heavyer) and I'd like to know how people are using this midbass.
The CH is quite different from the CY, not just the higher QTS.
Anybody did work with the W15CH001?
Old 8th June 2006, 08:51 AM   #10
for simple box tuning the parameters needed are Fs, Vas and Qts.
According to Seas site Fs = 38 Hz and Vas = 14L for both drivers.
/sreten.
DIY system with Seas Excel and Hiquphon? caz Multi-Way 8 10th July 2009 02:02 PM
Seas MTM enclosure question mathman Multi-Way 8 12th December 2006 03:11 PM
Eton 12 inch woofer/Hiquphon/Morel/accuton/seas excel M15 mmm12dna Swap Meet 2 29th December 2005 09:51 PM
Sub enclosure for Seas W26 graks Subwoofers 2 23rd February 2005 09:02 AM
Enclosure for seas lawbadman Multi-Way 2 24th May 2003 08:28 PM
Page generated in 0.31407 seconds (27.45% PHP - 72.55% MySQL) with 11 queries
