Old 6th March 2006, 11:59 PM   #1
Default I couldn't bear to throw them away...
so I rounded up all the crappy drivers I had and made this OB:
All the drivers except the 12" unit were scavenged from what neihbours had thrown out, The 6" units & Tweeter are old Magnavox units, had to cut off the dust caps, they'd been poked in, the 10" unit is a Taiwanese,no name, 12" is a hi-Q Jaycar driver ~AUD50. The wood is some old cupboard doors.
Sound - pretty good, doesn't need much low EQ, very good on vocals, but some stridency in the upper mids makes it unlistenable on Heavy Rock. Considering the xover is only 2 caps (jeez I'm cheap...) (one for the tweet, 1 across the parallelled woofers which are in series with the mids, which probably can't handle more than 5-10 watts) that's not too bad.
Just need to refine the xover & pretty them up
Pete McK
Old 7th March 2006, 12:28 AM   #2
adason is offline adason  United States
adason's Avatar
eexcelent, i love it! i like your alon type open baffle shape
diy at its best
use the inductors for woofers, that will improve the midrange a bit
otherwise not much else for crossover is needed
e
Old 9th May 2006, 11:54 PM   #3
Default finally got around to it...
added a 3mH choke across the mid drivers (this is a series xover)... now they sound awesome, really smooth all the way down on double bass, I add just a touch of lows on the tone control to get overkill kick drum on modern music (Black eyed peas etc), and a touch of highs to make up for the inefficient tweeters (they're really old, with tiny magnets)
Even better - WAF is 100%, the missus loves them...
Pete McK
Old 10th May 2006, 04:43 PM   #4
Speakerholic
Cal Weldon's Avatar
It's nice to use up some old stuff and have it sound good isn't it?
One question: Is that really all of your old crappy stuff?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th May 2006, 10:01 PM   #5
... well no, I've got much more stashed in the garden shed....
Old 10th May 2006, 10:05 PM   #6
tade is offline tade  United States
Send a message via AIM to tade
i like your comment about rock. I think rock is a really good demo of how good yoru system is, expecially when you crank it up. I know lots of beautiful, soft, acoustic jazz stuff which will float you away on even crappy speakers, but try playing metallica... Most likely not gonna happen.
Old 10th May 2006, 10:19 PM   #7
... and in the garage, and in the workshop....:-)
(just call me magpie)
Re: Rock, I've haven't tried the System of a Down CD yet, I suspect I may need to zobel the mids to tame the stridency,
but I ususally play the Heavy stuff on my garage system so I don't annoy the neighbours too much - but much to my surprise, the OB bass can do that when wound up too....
Old 10th May 2006, 10:21 PM   #8
Speakerholic
Cal Weldon's Avatar
Uh huh! Thought so.
Old 10th May 2006, 10:35 PM   #9
why must we be plagued to collect junk! I keep collecting random electronics in the hope of using some of the components...
Old 11th May 2006, 06:21 AM   #10
frugal-phile(tm)
planet10's Avatar
I have a bit saved up too ....
Pete. You get a Frugal-phile(tm) award for those.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
A question I couldn't answer... johnthedoctor Instruments and Amps 4 1st April 2006 08:53 AM
The Bear's new Aleph-X sbear Pass Labs 14 4th June 2005 10:51 AM
Couldn't resist this is too funny corryn00 The Lounge 0 31st January 2005 04:16 AM
Bear Symphony #1 mikeks Solid State 37 23rd October 2004 02:06 PM
Page generated in 0.12550 seconds (72.00% PHP - 28.00% MySQL) with 11 queries
