Old 5th March 2006, 03:33 PM   #1
reins is offline reins  Germany
Default Waveguide and bafflestep
as I'm playing around with waveguides for the tweeter, a question comes to my mind:
if I use a waveguide for the tweeter, the sound has a higher directivity and therefore might not see the Baffle any longer. SO, no influence of the baffle dimension in the frequence range of the tweeter.
Is that a valid conclusion?
Stephan
Old 5th March 2006, 10:49 PM   #2
lndm is offline lndm  Australia
As long as the waveguide is large enough to act as the baffle down to your frequency of interest.
Imagine rings of sound (domes actually) riding out of the waveguide on its surface - like detergent bubbles.
Old 6th March 2006, 01:35 PM   #3
Let's assume a 6" waveguide, from which frequence on baffle diffraction effects might be significantly reduced?
Stephan
Old 7th March 2006, 01:00 AM   #4
Take the speed of sound (344m/s), divide by the circumference of the mouth. This will give the frequency (give or take an octave for good measure), below this the waveguide will effectively disappear.
You also cannot reproduce low frequencies unless the length (from cone/dome toward you) is significant compared to a wavelength of the frequency of interest.
Try 'Hornresp' by David J McBean. Create a virtual horn that resembles your waveguide.
Old 7th March 2006, 03:49 PM   #5
Good idea, I wasn't aware that Hornresp could calculate the directivity. The result wasn't as expected, directivity is not significant in the range between 1kHz and 10kHz (-2 dB at 1kHz down to -6dB at 10kHz at 80° off-axis)
Stephan
DIY Waveguide loudspeaker kit gedlee GedLee 2031 24th August 2011 01:47 PM
Horn vs. Waveguide gedlee Multi-Way 1653 25th May 2010 07:38 AM
FullRange driver and bafflestep? Twisted85 Full Range 5 27th May 2009 03:27 PM
Page generated in 0.06764 seconds (79.50% PHP - 20.50% MySQL) with 10 queries
