I am trying to come up with a simple 2-way design with a ported box. Being a beginner, i was using win isd to get a box volume, port, etc. looking at several small ( 4-6in) woofers by dayton and Hi-Vi, win isd would return small boxes (good) with extremely long ports (bad). by long ports, i mean greater than a meter. What am i doing wrong?
I have used this program with single driver designs with good results. thanks tom |
#2 |
What drivers are you looking at?
Sometimes with a really long port, you can use two (2) smaller ports. The two smaller ports are shorter but sometime not by much. NOTE: When calculating the length for dual ports, be sure to cut the internal box volume in half.
Audio DIY Page FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account. |
#3 |
Here are some calculations I have for a 6.5" Dayton Classic Woofer. I used a 2" port @ approx. 8" for a Tuning of approx. 37 Hz.
#4 |
Doubling the ports - lengthens them.
Increasing the box size - decreases the length. Decreasing the diameter - shortens them. Bad! Increases the chance of chuffing. Try square or rectangular ports. Just click on the circle in WinIsd and it changes to a square. |
#5 | |
Box Enclosure: 1.5 ft^3 Fb = 40 Hz Port Diameter: 4 " (1 port) Port Length = 11.18 " Box Enclosure: 1.5 ft^3 (0.75 ft^3 for port calculation) Fb = 40 Hz Port Diameter = 2" (2 ports) Port Length = 5.59 " each (assuming there are two) Granted, the total length of both ports is longer, but each individual port is shorter. JL Audio Tutorial: Ports
#6 |
those values look much better.
when i can get to my home computer i will give my values. somehow i was getting port legths of 3 or 4 meters and box volumes of 1/2 liter. this is impossible unless you are Dr. Who. I must be doing something very wrong, will double check tomorrow morning. thanks for the replies tom |
#7 | |
Hi, the equivalent of one 4" port is 4 2" ports. RJ is correct, as you will find if you do calculations for 4 ports. Or for 2 ports 0.7*4" diameter. |
#8 |
Good point.....I guess I was assuming a small reduction in port cross-sectional area.
| Ports - Where to buy? | pow216 | Subwoofers | 6 | 31st March 2005 03:34 AM |
| help on ports | sidd_raj2002 | Subwoofers | 3 | 17th January 2005 10:48 AM |
| Need some help regarding these ports | Xristo | Multi-Way | 2 | 5th November 2004 09:24 PM |
| Ports | Ryan_U | Multi-Way | 6 | 2nd November 2004 04:16 PM |
| curved ports vs. multiple ports | Craig | Multi-Way | 1 | 22nd September 2002 07:30 AM |
| Page generated in 0.11859 seconds (78.42% PHP - 21.58% MySQL) with 11 queries |
