Hey all,
I guess that I will try this again... Nobody seemed to want to reply to my last post. Hi + Loudspeaker design - omnisat style? Maybe I will be more specific. I am looking for help designing a passive xover for a few drivers. They are all MB Quart drivers and I can't help much for the t/s parameters for them, I can just give you the resistances of the drivers and the x-over points that I would like to have them at. I tried searching the forum and found a few different sites and examples to use, but I would like some help if possible. I have 2x 4ohm (3.5 measured with meter) 6.5" drivers that are mounted isobarically and wired in series to give me an 8 ohm (7ohm measured) bass section (downward firing) and I have an 8ohm (aluminum dome mid) and a 6ohm tweet for this system that I need a xover design for. I would like to have the xover points to be ~500hz and ~3200hz respectively. I did manage to find a spec sheet and frequency responce graph for the mid, if that helps. Here is the specs that I have for the mid. They are in german, but I think it is understandable (the numbers anyways) * Frequenzbereich nach DIN: 250- 10000 Hz * Belastbarkeit: 100 W mit 12-dB-Weiche bei 850Hz * Mittl. Kennschalldruck (1W, 1m): 90 dB * Resonanzfrequenz: 500Hz I am planning on having the bass drivers fire downward and the mid and tweet fire in an omnipolar way. I am not sure what the result will be yet, just something that I am playing with. I hope that someone can give me a bit of help on the xover. This is where I am getting lost. Thanks.
Chris Nicholls |
#2 |
one more graph for the mid...
Chris Nicholls |
#3 |
Maybe you ask "too much"..... I have a friend that he do not believe at measurements and sophisticated simulation. He simply calculate theorical x-overs on 8 ohms load and so on. Incredible mystery but , sometimes, his speakers do not sucks!! He adjust a bit by ears and voilą, the speaker is made! Joke apart, I suggest you caution and a 1000Hz 12dB octave for the mid, 3500-4000Hz for the tw. If you can, check the speaker's impedance curve (for amplifier's safety!). MB quart was great domes. Cheers, Inertial |
| Yet Another DIY Xover ? | iain42 | Multi-Way | 7 | 21st January 2009 01:28 AM |
| Is there such an AMP/EQ/XOVER | Horizons | Car Audio | 1 | 22nd November 2008 07:50 AM |
| Xover | Ruben | Multi-Way | 0 | 21st October 2003 01:05 PM |
| What is C12 in this xover? | peterpan | Multi-Way | 3 | 20th June 2003 05:27 PM |
| Page generated in 0.07875 seconds (69.67% PHP - 30.33% MySQL) with 11 queries |
