Hi all. I am new to audio design. I just bought a loudspeaker rated at 8 ohms 30W and was told that I could connect it to the output of a standard hifi.
The question is does the power rating give any information of the maximum voltage and current that i can apply to the speaker without damaging it? I am trying to design a power amplifier to drive this speaker and is considering to use the TDA1560Q amp chip from Phillips since only requires a low voltage input. The chip is rated at 40W. Will there be any chance of me damaging the speaker since the speaker is only rated at 30W? Thanks in advance for helping to answer my queries. |
#2 |
Depends on your box and other things. Try using a good box simulator. These can show cone excursion, max attainable SPL's and thermally limited output (power handling).
| Newbie needs help DIY loudspeaker | joakim4156 | Multi-Way | 6 | 19th February 2008 10:52 AM |
| I make amp tda1560q. It not turn on Help! | jinkuchi | Chip Amps | 3 | 10th May 2005 04:40 PM |
| Newbie need help to build 2-way bookshelf loudspeaker!!! | thomgun_lc | Multi-Way | 3 | 16th April 2005 05:09 PM |
| Newbie need loudspeaker design advice | rockstilo | Multi-Way | 1 | 4th March 2005 01:42 PM |
| Altec loudspeaker : Newbie needs advice please :) | SpyStyle | Multi-Way | 9 | 11th February 2004 01:35 AM |
| Page generated in 0.10349 seconds (46.93% PHP - 53.07% MySQL) with 10 queries |
