Old 2nd March 2006, 08:26 AM   #1
Send a message via AIM to goodspeaker Send a message via MSN to goodspeaker Send a message via Yahoo to goodspeaker
Default Starting new project on ETON
Just started paper work of my new project on Eton 5-880/25hex+25sd1 in MTM configuration.
Calculated in BassBox6Pro ported volume for two midbass is 12 liters with Fb52Hz.
Box would be made from 18mm ÔÀÍÅÐÀ, maybe front baffle from 18mm ÔÀÍÅÐÀ +12mm MDF. Your suggestion? Driver put together as closer as possible.
I do not wont crossover in critical range. I see frequency response, it seems that 5-880/25hex works to on axis 5kHz (unfortunately I do not have off axis freq. response) then started to beam on 6.5kHz. So I think to crossover midbass on 4.5kHz with 2th order. Your suggestion? And make series resonance LCR network to low down beaming on 6.5kHz, I do not how to calculate this kind of network, so your help would be appreciated.
If I cross on 4.5kHz far away from tweeter resonance (1kHz), so I try to cross tweeter with just one condenser 1th order.
Coming one more new project on Eton ER4+4-300/25+7/360/37 in TMBB.
Old 2nd March 2006, 02:44 PM   #2
Inductor's Avatar
Hi goodspeaker.
The 25 sd1 ETON have a nice response curve.
I like the HEXACONE technology of the 5-880/25 Hex ETON.
What x-over are looking at? Would you like, say a 12dB (second order) 2k5Hz with no attenuation because you are using 2 mid-bass of 87dBs (+/- 90dB) and the tweeter is 90 dB SPL.
Why are trying to cross the tw with one cap only? I have a graph that shows that this MiD-WO doesn't work properly after 3K. Conservative limits are on the 2K16 anyway with maxs at 4Ks.
Old 7th March 2006, 05:35 PM   #3
Inductor's Avatar
With only a cap for first order x-over, the resonance of the tweeter interferes with x-over response even at 4k and more.
X-over freq. 2kHz second order.
-Wo. ETON 5-880.25hex-8, 88dB@2k, x2(+/-3dB)
(atention: wo. w/erratic behaviour after 3k because of rigid Hexacones)
-Tw. ETON 25sd1-8, 90dB
(flat frequency response from 900Hz to 20kHz)
Inversion polarity for tweeter because of 2.order x-over.
A) With this one you get a very nice and 'slim' x-over but the HF from the tweeter must be to high for about 0.5dB or so.
Parts List:
Capacitors
C1 = 18 uF
C2 = 6.8 uF
Inductors
L1 = 0.91 mH
L2 = 0.35 mH
Resistors
R = n.a.
R1 = n.a.
R2 = n.a.
B) So I would trim that (HFs) with this (one x-over):
See that L1 changed and we added a resistor R in series w/C1 to the mid-woofer x-over circuit. We have now some attenuation also for the tweeter.
Parts List:
Capacitors
C1 = 18 uF
C2 = 6.8 uF
Inductors
L1 = 0.82 mH
L2 = 0.35 mH
Resistors
R = 0.47 Ohms
R1 = 0.22 Ohms
R2 = 200 Ohms
(Tw. Atten. –0.3dB)
or:
R1 = 0.33 Ohms
R2 = 100 Ohms
(Tw. Atten. –0.5dB) (flat tweeter 0dB)
R1 = 0.47 Ohms
R2 = 82 Ohms
(Tw. Atten. –0.7dB)
R1 = 1 Ohms
R2 = 47 Ohms
(Tw. Atten. –1dB)
R1 = 1 Ohms
R2 = 33 Ohms
(Tw. Atten. –1.5dB)
R1 = 1.5 Ohms
R2 = 27 Ohms
(Tw. Atten. –2dB)
C) If the two woofers and the tweeter (flat tweeter 0dB) have about the same acoustic pressure (dB SPL) YOU CAN USE THIS ONE:
Parts List:
Capacitors
C1 = 18 uF
C2 = 8.2 uF
Inductors
L1 = 1 mH
L2 = 0.35 mH
Resistors
R = n.a.
R1 = 1 Ohms
R2 = 33 Ohms
That might help anybody using etons.
There are a few x-overs on the Eton website but (I would not use them) I think they are not appropriate for this situation, only as an idea.
Old 7th March 2006, 05:42 PM   #4
Inductor's Avatar
1st x-over/w. no attenuation.
Old 7th March 2006, 06:53 PM   #5
Inductor's Avatar
Wait, sorry guys.
That is for one (1) Eton speaker (woofer).
For two (x2 in series) you just have to change components:
Parts List:
Capacitors
C1 = 9.1 uF (one half from previous)
C2 = 8.2 uF
Inductors
L1 = 2 mH (double from previous)
L2 = 0.35 mH
Resistors
R = n.a.
R1 = 1 Ohms
R2 = 33 Ohms
In the figure the horizontal line where the two freq. responses cross is the -3dB line.
Old 7th February 2009, 08:18 PM   #6
GOWA is offline GOWA  Canada
GOWA's Avatar
Not much help here either.
http://ldsg.snippets.org/vendors/eton.php
I think that GR Research had an MTM with those drivers.
Website
New ClassD project Starting from 0 DjLeco Class D 232 19th May 2010 10:36 PM
Starting project needed... keantoken Everything Else 4 28th October 2006 11:19 AM
Starting a buffer project enter Chip Amps 7 13th April 2006 06:38 AM
Starting my first project. sachi Multi-Way 71 18th August 2005 11:52 AM
Page generated in 0.10654 seconds (75.64% PHP - 24.36% MySQL) with 11 queries
