Old 2nd March 2006, 07:04 AM   #1
Send a message via AIM to goodspeaker Send a message via MSN to goodspeaker Send a message via Yahoo to goodspeaker
Default what use for internal driver wiring?
What I can use for internal driver wiring?
From crossover to driver.
I head that for tweeter and woofer would be different cable.
I head that LEATZ(maybe wrong spelling) cable is special for internal wiring. But where to buy the one?
In internet I fond only silvered military cable, what can suit for DIY
here
http://stores.ebay.com/Johns-Silver-...dZ2QQpZ2QQtZkm
What is your opinion is it OK for my purpose?
Old 2nd March 2006, 07:37 AM   #2
Geek's Avatar
You mean Litz wire? That stuff is "ouch", unless you get it surplus
You didn't mention power level, but 16-18GA regular speaker wire is what I use for < 100W.
Old 2nd March 2006, 10:42 AM   #3
Scottmoose's Avatar
Silver in contact with Teflon is a very bad idea. You get measurable ringing; it's the worst combination I know of in terms of triboelectric distortion. That's why it's almost never used for microphone cables, and it's also probably where the commonly reported 'silver sheen' comes from. Its resistance is lower than copper, but only by a tiny amount -it won't make a whole lot of difference unless you've got 1/2 mile runs or so.
A popular soulution is to use a cable with a large cross-section for the bass drivers, and a different one with a large surface area for the HF). I doubt it'd make a great deal of difference, but give it a try. Just don't waste your money on high-priced stuff; the electrons don't care one way or the other how much you paid for it.
Best
Scott
Old 2nd March 2006, 10:46 AM   #4
Glowbug is offline Glowbug  United States
Glowbug's Avatar
http://www.knukonceptz.com/productDe...rodID=KAR16BLS
Jim J.
Old 2nd March 2006, 12:51 PM   #5
Gmorris is offline Gmorris  United States
http://www.markertek.com/Product.asp...&search=0&off=
Old 2nd March 2006, 03:48 PM   #6
Both links are usual speaker wire from amplifier to speaker.
But I think for inner speaker wiring I need to use nor usual speaker cable, but some kind of special cable. Maybe I wrong.
I was surprised when I fond that driver and speaker builder
http://www.aurumcantus.com/ (just check hifi loudspeaker link Supreme) uses for internal speaker wiring usual speaker cable Supra, actually I’m distributer of Supra in Ukraine so I have a lot of Supra cables on stock.
Is it good idea to use usual speaker wire for internal speaker wiring?
What are you use for internal speaker wiring? Maybe Litz?
Old 2nd March 2006, 04:22 PM   #7
I would use what you have in stock although I believe some feel that tinned copper is not recommended. I don't think that higher powered signals, such as those powering a speaker, will be affected much by cable over the short distance in a speaker box.
However I'm sure some will disagree.
The canare cable I linked to above has four conductors which, when hooked up in "quad" configuration, lowers inductance but also raises capacitance a bit.
http://www.tnt-audio.com/clinica/star.html
http://www.audioholics.com/techtips/...les/cables.htm
Internal Wiring... Tomv Multi-Way 1 23rd November 2007 08:53 AM
dac internal wiring sparkle Digital Source 16 8th May 2005 10:52 AM
Internal wiring Scribble Chip Amps 1 4th November 2004 05:52 AM
Internal wiring? Mayday Multi-Way 22 5th March 2004 09:54 PM
Internal wiring KenP Solid State 18 6th December 2002 09:59 PM
Page generated in 0.09234 seconds (78.75% PHP - 21.25% MySQL) with 10 queries
