High Sensitivity, low cost bookshelf speakers?
Old 28th February 2006, 07:51 PM   #1
jonnythan is offline jonnythan  United States
Default High Sensitivity, low cost bookshelf speakers?
I just purchased the $25 Sonic T-Amp for a bedroom system.
The thing is fairly low-power, so I'm looking for some high-sensitivity (>90dB) speakers that would go with it. It's a bedroom system that will never be driven very loud. CD's from a cheap-ish stereo and XM.
I'm considering some commercial speakers (Klipsch, for example), but I'd enjoy building a set myself.
Looks aren't very important.
I'm trying to keept he budget under about $150 for a pair.
Any suggestions?
Thanks!
Old 28th February 2006, 07:59 PM   #2
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Head over to the Fullrange forum and do a search on Fostex. If your budget is just $150, it's your best bet.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
Old 28th February 2006, 08:03 PM   #3
Glowbug is offline Glowbug  United States
Glowbug's Avatar
Sounds like a set of FE127E's in small transmission lines may be your best bet.
Maybe for a big bookshelf
Old 28th February 2006, 08:10 PM   #4
Thanks for the replies so far.
I've never really heard about full-range speakers before. Looks like I have plenty to learn!
What about these, out of curiosity:
http://www.diyhifisupply.com/diyhs_speaker.htm
I'm currently building a subwoofer and using WinISD to design it. How does one design an enclosure for a full range speaker?
Old 28th February 2006, 10:22 PM   #5
AJinFLA is offline AJinFLA  United States
Banned
Fullrange speakers - like the Fostex - are efficient, have very good midrange and imaging. They also have poor treble and non existent bass. Their poor overall frequency response and high levels of distortion add a coloration to the music that some will find appealing. Kind of like listening to an old AM radio. A very retro sound if thats your thing. An alternative for your T-amps limited power and $150 budget is something like this http://www.pispeakers.com/catalog/pr...products_id/34
May not quite match the Fostex in the mids/imaging, but will be light years better everywhere else. It will have plenty bass for your bedroom and a drumstick will sound like it struck a cymbal rather than a paper plate. Don't expect the worlds best for $150/pr, but these should do the trick.
The Hifisupply driver looks interesting. Won't get as loud as the Pi's, but if thats not a priority, might be worth looking into. A bit of an unknown at the moment. Good luck.
AJ
Old 28th February 2006, 10:26 PM   #6
leadbelly's Avatar
You can get Fostex for less than that price, that's what I would do. Lot's of designs, tweaks, products for Fostex out there.
Well, if you want to go with sealed or vented, just use WinISD as you would for a sub. If you want to get fancy like t-lines and such, go check out the info and designs in the Fullrange forum. Personally, I would try for an aperiodic box if trying to make a fullrange bookshelf.
Old 28th February 2006, 11:27 PM   #7
nerd of nerds is offline nerd of nerds  United States
maybe you don'e really neeeeed high sensetivity drivers...
I'd recoment zaphs hi-vi b3s design for that amp...although i haven't heard it i'm driving mine with similar power and they work great...
www.zaphaudio.com
Old 1st March 2006, 12:50 AM   #8
FourDegrees11 is offline FourDegrees11  United States
This is a little out of your price range ($350), but I would go with the Adire HE10.1 Mark II. A true 95 db, 8 ohm load, with bass down to the 50hz region.
http://www.adireaudio.com/Home/KITHE10-1.htm
High Sensitivity, low cost bookshelf speakers?Hide this!Advertise here!
Aleph 30's with low sensitivity bookshelf speakers?? spzzzzkt Pass Labs 9 7th July 2008 03:51 PM
High sensitivity(>90db) budget speakers wanted kmj Multi-Way 40 28th April 2005 04:23 AM
New to DIY... Looking for something w/ high sensitivity. DonoMan Multi-Way 25 10th February 2005 02:58 AM
low cost (£70 max), near field monitor/bookshelf speaker. Puggie Multi-Way 7 24th October 2004 09:36 PM
