Hello,
I bought the dc speakers protections VellemanK4700. I want to use these into a multiway active speakers system so I want that the kit can detects not only a DC at the amp output but also signals below a fixed frequency ( about 100 hz for one channel and 800 Hz for the other channel ). How can I do this? Replacing the C7,C8 (C9,C10) caps? Link to the circuit http://www.velleman.be/downloads/0/i...nual_k4700.pdf Very thanks |
#2 |
the obvious question is why ? what fault conditions would cause unwanted frequencies at the outputs of your amplifiers ? A much simpler protection scheme for your mids and tweeters is fitting series capacitors to each driver, DC and low AC protection. |
#3 |
>cause unwanted frequencies at the outputs of your amplifiers ? Because it just happened to me. Due to a bad contact in the connector inside the behringer dcx 2496 crossover, my scanspeak 9700 tweteer fried receiving an high volume 'scratch'. >A much simpler protection scheme for your mids and tweeters >is fitting series capacitors to each driver, DC and low AC >protection. I agree, but the approach to an active multiway system is to eliminate the passive components |
#4 |
anyone can help me ?
| Audio Amplifier protections | aguantesoda | Solid State | 12 | 12th April 2007 10:28 AM |
| OP AMP tutorial, protections,... | pat allen | Everything Else | 5 | 16th January 2007 07:43 PM |
| Lm1875, Emc Protections | alcuemar | Chip Amps | 3 | 24th May 2006 05:07 PM |
| eq for low freq channel | hakalugi | Subwoofers | 9 | 11th August 2005 08:59 PM |
| Driver ratings and protections | jackmcdowell | Multi-Way | 4 | 14th July 2004 10:08 AM |
| Page generated in 0.08096 seconds (73.10% PHP - 26.90% MySQL) with 10 queries |
