Old 26th February 2006, 11:01 PM   #1
Sparhawk's Avatar
Default 12" woofer upgrade - sealed or ported?
I have some old DIY speakers that I'm thinking about upgrading. I started another post about the mid/tweeter replacement here . I've pretty much decided on the Peerless HDS 152 and Seas 27TDC for the mid and tweeter, with the crossover described here .
But now I'm thinking about replacing the woofers too. Currently these
cabinets are 100 litre sealed boxes.
I'm looking at the NHT1259 and the Dayton RSS315HS. The NHT looks very good in a 100 litre sealed box. The Dayton looks okay, but looks much better in a vented box. But the port (tuned to 21Hz) is very large, and would decrease the box volume.
Any thoughts? Any other drivers I should be considering?
Old 6th March 2006, 06:34 PM   #2
Most programs and recommendations for port diameter exaggerates the necessary dimensions. You´ll be fine with two 3" ports. Also, standard port calculations will give you a too low tuning. See http://www.troelsgravesen.dk/vent_tuning.htm
BTW, I´d go for the NHT in a closed box..
Old 6th March 2006, 07:32 PM   #3
Kittle is offline Kittle  United States
Tha NHT driver is good stuff
In a closed box (3.5^3 ft) yeilds neighbors asking you to turn the bass down
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 03:45 PM
22W/4851T Revelator 8" woofer an upgrade for 21w-8554? Daveis Multi-Way 0 9th October 2007 02:14 AM
what size sealed or ported box can this woofer use ? zuki Multi-Way 2 23rd November 2004 02:20 AM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
suggestions; looking for shallow 10 or 12" woofer to work in small sealed box zuki Multi-Way 6 1st April 2004 06:21 AM
Page generated in 0.09038 seconds (51.39% PHP - 48.61% MySQL) with 10 queries
