Old 25th February 2006, 10:48 PM   #1
bcherry is offline bcherry  Hong Kong
bcherry's Avatar
Send a message via Yahoo to bcherry
Default Speaker Works: SI T amp doesn't work with soundcard
An otherwise healthy SI T amp doesn't get along with the Soundmax soundcard in my Dell. Once in circuit with the Wallin jig, it emits a 'ticking' beat irrespective of volume setting. No signal throughput. A tube amp in the same setup works fine (I'm surrounded by tube amps and only have this one SS amp). Anyone have any ideas why the soundcard and T amp won't talk to each other?
Brian
Disclaimer: I may or may not offer for sale items mentioned in this thread, and if I do, I may or may not make a profit.
Old 26th February 2006, 06:36 PM   #2
Probably because the T-amp is a full-bridge output, and the Wallin jig ties one side to ground/common. The digital/switching amps are not good choices to use for this type of measurement app for that reason - the two outputs need to be isolated from the signal ground. You can do it with cap coupling, but then you're introducing a high-pass which you have to be careful about.
Old 27th February 2006, 04:23 AM   #3
bcherry's Avatar
Default So that's what a digital ground loop sounds like.
Thanks for the reply.
I've also tried an otherwise quiet p-p tube amp that hums when connected through the Wallin jig.
What amps are Wallin jig users, using?
Brian
How do you measure drivers, what works/doesn't work pjpoes Multi-Way 5 20th July 2008 04:45 AM
Good soundcard for lap top that works with soundeasy? Jim85IROC Multi-Way 28 27th February 2008 01:09 AM
If Speaker Workshop doesn't work??? Pbassred Multi-Way 3 8th January 2006 09:13 AM
LM2574 + FET =-> doesn't work Danko Power Supplies 2 7th July 2005 07:42 PM
Page generated in 0.08318 seconds (58.45% PHP - 41.55% MySQL) with 10 queries
