Hello,
I'm trying to build a decent quality multi-channel system. Fronts are Sonus Faber Signums. Rears are Sonus Faber Concertinos. I'd like to consider building something for the center channel. Looking over the kits offered by Madisound or others, what would blend well? Thanks and regards, Rob |
#2 | |
Raah, destroyed my message...
These might work just fine: http://www.troelsgravesen.dk/W1500_97.htm http://www.troelsgravesen.dk/W1501_95.htm http://www.troelsgravesen.dk/HDS134_DX.htm ( http://www.madisound.com/vifastudio.html ) Gotta love Troels' designs. |
#3 | |
Sonus Faber prefers first order cross overs. Most of the MTM designs I've looked at for a center channel have higher order networks. Is this a real concern for purposes of integration? What do you think of the Lynn Olson's ME2 or SEAS Froy? The latter looks good on paper, and there's a favorable test report in AudioXpress. Any idea if these would integrate well with Sonus Faber? Thanks and regards, Rob Weinstock |
#4 |
Are you sure you want a centre? If you have phantom centre mode and your screen is between your mains, there is really very little point, and it will most likely sound worse.
| Soliciting center channel advice to match my existing system | Jason_AZ | Multi-Way | 1 | 17th March 2006 03:29 PM |
| need a center speaker..help!! | cybermunster | Multi-Way | 1 | 5th September 2005 04:19 PM |
| Guidance for my new 7.1-System needed (Center, backward-Speaker) | Blitz | Multi-Way | 1 | 16th May 2005 06:32 PM |
| Center speaker | Oxanest | Multi-Way | 3 | 11th June 2004 11:22 AM |
| Scanspeak Center Speaker | Faberian | Multi-Way | 15 | 18th April 2003 06:17 AM |
| Page generated in 0.07692 seconds (78.43% PHP - 21.57% MySQL) with 10 queries |
