Old 23rd February 2006, 07:16 AM   #1
Sujies is offline Sujies  India
Default Driver Paramameters
hello guys i was measuring driver params of a local driver and i got some wrong values and always get the same ,
can anyone tell me what is going wrong
Source Voltage Vs 0.99
Source Resistance Rs 9.70
Speaker DC resistance Re 7.80
Voltage across R 0.55
Source current (DC) Is 0.06
Voltage across R at resonance Vm 0.45
Current flow at resonance Im 0.05
Resonance frequency Fs 29.00
Speaker impedance at resonance (Rm) Rm 11.50
-3dB current Ir 0.05
r0 1.21
-3dB voltage Vr 0.50
Fh 32.00
Fl 27.00
Fs check 29.39
Cubic Feet of test box Vb 0.41
Resonance of driver in test box Fb 11.00
Vas -0.35
Qms 6.38
Qes 13.46
Qts 4.33
Old 23rd February 2006, 08:36 AM   #2
e-side is offline e-side  Netherlands
Default Re: Driver Paramameters
Vas -0.35
Qms 6.38
Qes 13.46
Qts 4.33
You've got a very low impedance at the resonance frequency Fs.
The resonance of the driver in the test box is lower than the free air resonance, while it should be higher.
You might have done something wrong. If you're sure you didn't, then you could try the measurement instuctions at http://www.epanorama.net/documents/a...arameters.html.
hope this helps
regards
Erwin
L-pad attenuator for midrange driver 6 1/4 inch driver rhythmdiy Multi-Way 0 4th November 2007 03:32 PM
Base driver to suit ESS Heil driver gerado Planars & Exotics 6 1st August 2007 07:56 PM
FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) theAnonymous1 Swap Meet 0 24th April 2007 12:09 AM
Driver/ driver configuration improve soundstage width andy2 Multi-Way 6 16th June 2005 08:47 PM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Page generated in 0.07068 seconds (75.09% PHP - 24.91% MySQL) with 10 queries
