I would like to build a pair of very high quality PA speakers, my criteria are basically high quality, low distortion sound down to about 50-60Hz, they will be mainly used on voice and acoustic guitar. I have got the following midbass drivers (Volt BM251.4) in the 4Ohm version (these specs are for the 8Ohm)
Fs 57Hz Re 5.2ohms Qa 2.9 Qe 0.37 Qt 0.33 Vas 38litres Xmax 2.5mm Sd 288cm2 Vd 72cm3 Le 0.8mH I've had a play and come up with about 30l tuned to 55Hz, this should give me a good response down to about 50-60Hz then rapid roll off. My intention is to partner them with something like a Fountec Neo2 ribbon or similar high efficiency large ribbon, porribly slightly waveguide/hornloaded. can anyone come up with anything better? TL/MLQWT/etc? thanks. |
| The best 5" midbass ever | gainphile | Multi-Way | 2 | 16th April 2008 01:28 AM |
| 7" midbass and 1" tweeter for 60$ and 30$, what about SEAS? | Bricolo | Multi-Way | 23 | 20th July 2007 04:35 PM |
| choosing 8" or 6.5" midbass | neon | Multi-Way | 11 | 19th March 2005 04:32 PM |
| Looking for a high-end 8"-10" (20cm) midbass | Vortex | Multi-Way | 25 | 31st January 2004 09:03 PM |
| best midbass for a horn "mini" monitor? | E. Billeci | Multi-Way | 2 | 13th January 2004 06:46 PM |
| Page generated in 0.05974 seconds (68.09% PHP - 31.91% MySQL) with 10 queries |
