Old 18th February 2006, 11:51 PM   #21
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I don't understand why anyone should be interested in Vas for a driver on an open baffle; Vas is a parameter that is relevant when dealing with boxes. On an open baffle, the only important parameters are fs, Qts, and efficiency. As a sweeping statement, output falls at 6dB/octave as frequency falls from an open baffle, and the frequency at which that happens is inversely proportional to the size of the baffle, so the primary consideration is the size of the baffle. In practice, there are ripples in the response caused by the peaks and nulls from in and out-of-phase addition. A bigger baffle makes the difference between the peak and null frequencies smaller, so it makes the amplitude of the peaks and nulls smaller. That's why a big baffle is better than a little one. I have a sneaking suspicion that there may be a critical minimum size of baffle related to the ear's FFT process and low frequency discrimination.
Once the applied frequency falls to fs, the 12db/octave attenuation of the driver is added to that of the baffle, or, to put it another way, there's no point in using a driver with a lower fs than the baffle response (equalised or not). Reduced fs always forces reduced sensitivity.
The graph in the earlier post demonstrated the effect of Qts. It's much easier to electronically equalise lower values of Qts.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 19th February 2006, 05:43 AM   #22
Raka is offline Raka  Europe
Raka's Avatar
It seems that everyone wants to talk about how to equalize a dipole, well the information is welcome, but is not the point.
Keltic, thanks for the link, it's very interesting the Vas value. In the AES paper Vas it's mentioned, but in a generic way and related to system efficiency.
What intrigues me is what happens to the cone modes if they are not damped by a closed box, and how to measure/valuate this effect.
What is beyond the speaker?
Dipoles ? LennyK Multi-Way 111 21st September 2006 03:12 PM
Dipoles (continued)... Nuuk Multi-Way 10 25th February 2006 07:52 PM
3-way or 4-way dipoles? mazeroth Multi-Way 0 25th January 2006 06:37 AM
SPL max and dipoles XLS Raka Multi-Way 11 21st July 2004 08:34 PM
'T' baffle dipoles sfdoddsy Multi-Way 2 15th January 2003 10:46 AM
Page generated in 0.09164 seconds (69.74% PHP - 30.26% MySQL) with 11 queries
