Two ports in a 2-way bass-reflex speaker
Old 15th February 2006, 05:12 AM   #1
alvinlim is offline alvinlim  Malaysia
Default Two ports in a 2-way bass-reflex speaker
I am thinking of putting in two ports at different frequencies to even out the bass response for a 2-way bookshelf speaker I am building. What are the implications of using 2 ports, instead of 1 port?
Thanks!
Old 15th February 2006, 09:36 AM   #2
R.I.P.
two staggered tuning ports should be tuned fairly near to each other.
If they are widely tuned, the lower tuned port is basically ineffective,
and the result is esssentially the same as one higher tuned port.
/sreten.
Old 15th February 2006, 09:42 AM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
That is true in theory, but this user has found possibly different results in real life.
http://www.diyaudio.com/forums/showt...207#post823207
Start from that point and read the successive posts
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 15th February 2006, 11:41 AM   #4
R.I.P.
two identical ports with length ratio's of 1.4 gives frequency
ratios of ~1.2. e.g. 40Hz and 47Hz, or 47 Hz and 56hz.
The thread indicates if anything the theory to be true,
as the higher tuned port has more effect than the lower.
/sreten.
Two ports in a 2-way bass-reflex speakerHide this!Advertise here!
bass-reflex with 2 different ports? andrew24 Subwoofers 6 4th July 2009 03:54 AM
Bass reflex theory: multiple ports Qp TG Multi-Way 3 18th November 2005 06:34 PM
8-12" Bass reflex Full range Corner speaker (mono) Howismydriving Full Range 2 23rd October 2005 08:50 AM
Do you stuff a bass-reflex speaker? type Multi-Way 10 23rd January 2005 02:27 AM
Nice looking reflex ports mark.carline Multi-Way 2 10th May 2004 07:39 PM
