Could someone explain the benefits to me why you would keep the low pass seperate and far away from the high pass on a passive crossover if you are not biwiring?
What are the disadvantages to having one board sharing the same negative ground path to the speakers? Thanks |
#2 |
diyAudio Moderator Emeritus
If the high and low pass sections use inductors then keeping them far apart and properly oriented (so their magnetic fields cross at a 90 degree angle) will reduce the interaction between the inductors. Ideally you want every component to have it's own separate path to a single ground point. That's often complicated if not impossible to do for some things so we make compromises. Just depends on how much you can or are willing to compromise.
Brian |
#3 |
It could also be the result of the enclosure design. Some crossovers just won't fit in the box all on the same board.
| FS: Conrad Heatsinks;.... 'PASS' B1 boards w/JFETS;...... F4 AMP & PSU boards | cowboy99 | Swap Meet | 5 | 25th August 2009 02:39 AM |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Pass Aleph 1.7 boards, Zhaolu 2.5A, P700 VRDS, UGS PS boards, dac chips | analog_sa | Swap Meet | 4 | 14th March 2009 05:29 PM |
| FT: Pass boards for P101 boards | bjefferys | Swap Meet | 1 | 26th March 2006 07:39 PM |
| high gain 2nd order high pass active filter topology | sreten | Solid State | 21 | 23rd March 2006 01:26 AM |
| Page generated in 0.07177 seconds (71.57% PHP - 28.43% MySQL) with 10 queries |
