I have seen the Titan's mentioned here and elswhere. I own 2 pairs, one Series 1 and one Performance Series...the quality of the Series 1 is way better..cast frame vs. stamped steel ect.
I heavily modded my Series 1 with cab bracing, deadning, better x-over caps,ect.. The little monsters sound pretty amazing with one exception..classic "one-note-johnny" bass typical of a small vented enclosure. Being impressed otherwise, I decided to analyze the Mid/Bass to see if a TL would be doable. I figured I would post the parameters in case anyone was interested. Measured... Sd=126.7 cm2/19.6 in2 Re=3.53 Fs=45Hz Qms=7.47 Qes=.39 Qts=.371 Vas=64 litre/2.26 ft3 (measured with 9 litre test box) Derived... Bl=3.399 Cms=2.771 10(-3) Mms=4.514 gr. no=1.45% SPL=93.6 My test bax was a little small, so I don't trust the Vas, or the derived SPL 100%. I may re-do with a bigger box, but these figures aren't that important for TL design. Hope this is useful to someone, Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#2 |
given your parameters a reflex in a small box is not on. I think Vas may be off. |
#3 | |
The derived specs came fom the Mathcad T-S worksheets by Martin J. King. When I reversed the process to get Vas from the calculated Bl, it came back with a Vas of around 45 litre's...probably closer. Since I'm looking at a TL, I'm not to worried about the Vas..I measuered all this the old fashioned oscillator/meter way. Once I get Speaker Workshop all sused out, I will probably give it another go with a proper sized test box. Casey
#4 | |
#5 | |
I'm not looking to design anything too radical, basically scaling Martin's Fostex design in his worksheets. Since I'm looking at 3 X Sd for my CSA I think I should be ok. If anybody can see a error in my thinking, please let me know. Casey
| Paradigm TITAN MONITOR V5 CROSSOVER | sviru | Multi-Way | 5 | 2nd August 2009 08:40 AM |
| Paradigm Titan, Paradigm Phantom v1, a lot of help needed | duraznov | Multi-Way | 3 | 25th August 2006 03:36 PM |
| Paradigm Titan 6.5" driver | Sly-1 | Multi-Way | 0 | 26th November 2004 04:14 PM |
| Page generated in 0.08050 seconds (72.88% PHP - 27.12% MySQL) with 10 queries |
