Old 10th February 2006, 03:43 PM   #1
eag is offline eag  United States
Default Midrange Replacement
I was looking at the speaker project entitled "Jubilee". The midrange 2" that it includes in the design is no longer available at PE. It was: PEERLESS 821639 2" POLY DOME MIDRANGE 4 OHM
Can you recommend a replacement?
Due to price, replacemnets I've been looking at were:
http://www.partsexpress.com/pe/showd...number=285-010
http://www.partsexpress.com/pe/showd...number=297-415
If not those, what $30> midrange will fill the void in that project?
Old 10th February 2006, 04:21 PM   #2
I can recommend building something else, its a poor design.
/sreten.
Old 10th February 2006, 04:23 PM   #3
i searched jubilee here and numerous people suggested it as a good design
want to tell me why you think that way?
Old 10th February 2006, 04:39 PM   #4
Speakerholic
Cal Weldon's Avatar
sreten,
It's hardly fair to come on and say it's a poor design without backing it up.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th February 2006, 06:02 PM   #5
thalis is offline thalis  Greece
The Hi-Vi states 350Hz Fs in the manufacturer’s sheet and 800Hz in Parts Express description. If the manufacturer is right (probably), these two drivers look very similar from their specs and only listening to them would reveal their differences. Nevertheless, if I had to decide, I would go with the Hi-Vi just from ‘feeling’ :-)
Thalis
Old 10th February 2006, 06:29 PM   #6
So it is frequency # I should be looking at?
What about the cone midranges, will they have a significantly different sound?
I didn't think I'd have to add this question but I guess I do: What are the people's views on the Jubilee setup (those with experience with it)?
Old 10th February 2006, 08:56 PM   #7
Speakerholic
Cal Weldon's Avatar
All drivers sound different from one another. I think many feel that a dome mid is an acquired taste.
Old 13th February 2006, 09:03 AM   #8
Originally posted by Cal Weldon
sreten,
true, but really didn't have time to fully answer the question.
I'd be very suspicious of a speaker using a 1st order crossover
for a 2" dome midrange regarding distortion in the lower ranges
of the midrange dome.
I've now spent some time searching for data on the Peerless
driver and can't find any, and to be honest its difficult to back
up my assertion without any data to back it up.
/sreten.
Old 13th February 2006, 04:00 PM   #9
on paper the Hi-Vi is the likely better choice because :
It has a flatter response
It has a flatter impedance characteristic
It likely has a nearer sensitivity to the Peerless unit
/sreten.
Old 8th April 2009, 04:12 AM   #10
raypalmer's Avatar
Sorry to resurrect the dead here but....
Eag you out there? How'd this speaker turn out??
Wherever you go there you are.
midrange box Q. blue934 Multi-Way 6 8th May 2008 01:20 PM
which midrange? bcrazy Multi-Way 6 24th October 2005 02:00 PM
The best midrange Audist Multi-Way 31 19th August 2005 06:45 AM
ATC SM-150 Midrange Fuzzy_Logic Multi-Way 0 14th May 2002 07:44 PM
Page generated in 0.08896 seconds (87.14% PHP - 12.86% MySQL) with 10 queries
