Dayton+Hi Vi B3S+27TDFC 3-way concept review
Old 10th February 2006, 12:58 PM   #1
alexcd is offline alexcd  United States
alexcd's Avatar
Send a message via AIM to alexcd Send a message via Yahoo to alexcd
Default Dayton+Hi Vi B3S+27TDFC 3-way concept review
So, I had an idea for building a 3-way speaker the other day. I like the work Zaph has done on his website and it inspired me to try something with the HiVi B3S. I also have heard the Dayton 10" Hifi subs and love them. A friend is loaning me Seas 27TDFC tweeters to complete the setup. Does anyone see anything inherently wrong with this setup.
Here's the approx setup.
Drivers: 1 x Dayton 10", 4 x HiVi B3S, 1 x Seas 27TDFC
Room: 11' x 19'
Speaker Location: Near corners, maybe a little in
Potential crossover points: 200-400Hz?, 1.8kHz
Baffle width: 12-14"?
Old 10th February 2006, 04:03 PM   #2
R.I.P.
the B3S is a great full range driver by all accounts, but it is
not a great driver if you remove the full range requirements.
IMO using 4 of them as a midrange driver is not a good idea.
IMO one bigger and more expensive driver would be better.
/sreten.
Old 10th February 2006, 04:12 PM   #3
alexcd's Avatar
Ok, I see that someone else is thinking about doing 16 of these plus a tweeter line array style.
http://www.madisound.com/cgi-bin/dis...gi?read=371200
I may just follow along with what he's doing and add a powered sub later.
Old 10th February 2006, 04:42 PM   #4
dwk123 is offline dwk123
Well, I'm not sure I'd advocate following that project - the B3S line array + single tweeter is actually a pretty bad idea for several reasons.
First, point source bass + line array mid + point source tweeter is a recipe for disaster. Your on-axis spectral balance will only be right at one point, and your power response will be messed up. Plus, the c-t-c spacing requires rolling the B3S off early, once again not really taking advantage of it's full-range strength.
I like the B3 drivers (I have the N which looks nicer), but a line of 4 is problematic - it's not really a line array, but not really a point source either. This isn't to say it won't work, but IMHO spending another $10 per side and using a WR125s as a mid instead of the 4 HiVi's would be a much easier path to success.
If you *really* want to use 4 HiVi's, another idea would be a bizarre MTM setup with two HiVi's side-by-side making the mid. ie
MM
T
MM
I think this would have somewhat smoother power response overall than the line-of-4, and you wouldn't have any horizontal lobing problems between the M and the T.
Old 10th February 2006, 06:29 PM   #5
owdi is offline owdi  United States
owdi's Avatar
While the B3S is a nice speaker, it's just not in the same class as the Seas tweeter or Dayton woofer. For $40 you could pick up a pair of Dayton RS125s and go with a MTMW or TMMW design.
Dan
Old 10th February 2006, 07:00 PM   #6
alexcd's Avatar
On a totally seperate note, I like the idea of 2.5 way setups. I dont want to try MTM for my first speaker and 2-way is just too BORING for me. I know there are lots of designs available for this. Since I already have the 27TDFC I'll need to look for a driver to mate up with it but with solid low end so i can use it as a bass driver as well. I want a low distortion setup but not willing to pay $$$ for Seas Excel or SS mids.
Suggestions??
Old 10th February 2006, 07:35 PM   #7
sqlkev is offline sqlkev  United States
go with the rs125,
I think roman over on pe board has a 3 way setup with the rs 10" + rs125 + rs28
the tdfc isn't that far off from the rs28
Old 10th February 2006, 07:50 PM   #8
alexcd's Avatar
Got any links to the thread?
Old 10th February 2006, 08:00 PM   #9
woops, I found the link to his page http://www.rjbaudio.com/Daedalus/daedalus.html
the 3 way is actually consist of the 8"+4+1, not 10", my mistake.
You might want to email him if any changes can be made.
Old 10th February 2006, 08:02 PM   #10
alexcd's Avatar
Those seem fine actually. I meant to say that I didn't have a lot of power to dish out. I would have certainly needed plate amps for the subs anyways. Maybe I'll try these.
Dayton+Hi Vi B3S+27TDFC 3-way concept reviewHide this!Advertise here!
Dayton RS28AS-4 & Seas 27TDFC/G sephiroth619 Swap Meet 0 28th June 2007 08:32 AM
Help with 3-way crossover. Dayton Reference drivers w/ 27TDFC. Zaph? Others? wigginjs Multi-Way 9 1st March 2006 04:28 AM
Dayton Rs 7 + seas 27tdfc MTM bhg41088 Multi-Way 3 21st August 2005 08:15 PM
Dayton BR-1 "experiment" and review. netgeek Multi-Way 20 4th June 2004 10:08 PM
Copyright ©1999-2017 diyAudio
