Hello I has a pair of jensen field coil.One is 220905 ,4987 ,A0 20672 I ,F12N C4987 and cone number is 16781. another one is 220901 ,4986, A0 20672 I,F12N 4986 and cone number is 16781.
one fieldcoil has resistance 4.87k and another one is 237.0 ohms. Anybody can help me with this please? thank you. |
#2 |
Hi. If you look through the archives in the HiEff forum over at AA, you'll see that it's pretty common to happen across a pair of FC drivers with mismatched field coils. I think you'll also find that the f12n's are pretty ubiquitious on eBay right now, so you should have a pretty easy time finding a mate with the right FC resistance.
Regards, John |
#3 |
Thank you for your information.I'm already look at AA and seem make new Field coil is better solution
![]() Kris |
| Has anyone DIY a Field coil? | OzMikeH | Full Range | 18 | 16th November 2010 01:56 PM |
| Sensitivity of Jensen A-12 field coil speakers | korneluk | Full Range | 1 | 24th March 2008 06:05 PM |
| DC supply for Jensen A12 field coil driver | korneluk | Full Range | 1 | 21st March 2008 07:23 PM |
| Jensen A12/F12 field coil drivers T/S parameters? | mefistofelez | Multi-Way | 0 | 27th October 2006 04:23 AM |
| What's a Field Coil Amplifier? | krzanik | Tubes / Valves | 9 | 14th May 2005 03:22 PM |
