Quick question....Im almost completed with zaphs l18, and am on the port portion of the cabinet. Im placing a 2 inch port in the rear of the enclosure tuned @42 hz. My question is where the port should be located. Ive been reading that the the port should be behind the tweeter. Well currently the tweeter is off center due to the way the plans are designed. So...Now do I also place the port off center in the back or center with the rear baffle ?.....Also is what I read even correct??...should the port be behind the tweeter? Thanks guys.
Lete me know if you need me to clarify this a little better. Thanks |
#2 |
diyAudio Moderator Emeritus
It matters not where the port is placed. Just don't put it directly behind the bass driver. Apart from that shouldn't matter whether it's centred or not.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
| Optimal Port Placement. | Juggy | Multi-Way | 8 | 26th February 2009 01:48 PM |
| Port placement on MTM | squidbait | Multi-Way | 2 | 25th March 2004 02:26 AM |
| Port-placement uncertainties | rho | Multi-Way | 4 | 20th February 2004 06:12 PM |
| Port placement | Radik | Multi-Way | 7 | 15th November 2003 01:06 AM |
| multiple port placement.... | ChesterFuzzin' | Multi-Way | 1 | 17th May 2002 06:08 AM |
| Page generated in 0.06660 seconds (65.62% PHP - 34.38% MySQL) with 10 queries |
