Old 8th February 2006, 06:58 AM   #1
a2xm is offline a2xm  Indonesia
Default 2-way Philips crossover
Hi all,
I'm trying to build a 2-way crossover from Philips. I've the original old Philips drivers (7" woofer & 1" tweeter) and the how to book also original from Philips.
I did buy good capacitor and Solen air coils according to the scheme. But the scheme didn't show which is the negative and positive input. and also how to connect the coils & cap (which one is in/out).
I've attached the picture in this post or you can go here: a2xm.com/skema.gif
Any helps will be very appreciated. Thanks so much.
a2xm
Old 8th February 2006, 07:43 AM   #2
for inductors, film and reversible electrolytic capacitors
it does not matter which way round they are used.
Your diagram is fine, the top is usually the negative
input and the bottom usually the positive input.
/sreten.
FS Alnico Philips AD3800M AD3800AM and Philips transformers guglielmope Swap Meet 8 10th January 2011 11:28 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 04:21 AM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Page generated in 0.06136 seconds (69.93% PHP - 30.07% MySQL) with 11 queries
