Will soon be starting my next speaker project.
Have a question regarding timber. will be buying from here --> http://www.brims.com.au/ Have to decide between 'Brimsboard' or 'Brimsply'. One is ply, other is 7 layer HMR (moisture resistant particle) Want opinions as to which would be better (and why please) Is it worth using the 25mm over the 18mm ? (see above Q) Mainly interested in arguments regarding the sonic properties. Cabinets will be about 1000 h x 230w x 250 d with four braces. Edit; typo... |
#2 |
I'm an MDF person myself, but given the choice of the 2 brims products you mention - I'd go with the marine ply.
As to sizing, I have my mid-bass bins in 1" (25mm) MDF. The subby is going into 1" MDF, the top box is getting a 1" MDF front panel and 3/4" (18mm) side/back/bracing. If you can afford the extra, then 1" is good (you could used 18mm for the braces even) - and helps when it comes to rounding off the corners of the box. IMHO
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
| What's A "Timber bulb"? | DaveMcLain | Tubes / Valves | 4 | 28th April 2009 12:10 PM |
| Timber Panels | jamikl | Multi-Way | 3 | 3rd August 2008 12:20 PM |
| My sealed timber subs. | Foxx510 | Subwoofers | 12 | 28th March 2008 03:57 PM |
| Dual Arm Granite / timber Turntable | Mesh | Analogue Source | 3 | 9th November 2005 09:27 PM |
| Page generated in 0.07900 seconds (61.39% PHP - 38.61% MySQL) with 10 queries |
