any research into off axis response Vs tweeter face profile
Old 7th February 2006, 12:32 PM   #1
Puggie is offline Puggie  United Kingdom
Default any research into off axis response Vs tweeter face profile
As the title says; I've read Zaph's off axis tweeter response roundup and it got me thinking (that and pulling apart some ATCs whice use the Vifa D26 ceramic magnet with their own machined face plate), has anyone done anything similar, but tried a number of different profiles of face plate flare on the same tweet (or a selection of tweets)?
Old 7th February 2006, 08:08 PM   #2
Zaph is offline Zaph  United States
Zaph's Avatar
Default Re: any research into off axis response Vs tweeter face profile
Well, I once took a D26NC55, removed the flange and put a custom 1/2" waveguide on it. Results shown below. It put a mild boost centered at 3.5khz. It worked well to raise output in that area when used with a narrow cabinet that had a diffraction related dip there.
-Zaph|Audio-
Old 7th February 2006, 10:59 PM   #3
AJinFLA is offline AJinFLA  United States
Banned
When you say removed, do you mean cut it off, or is the faceplate actually removable?
AJ
Old 8th February 2006, 12:58 AM   #4
Zaph's Avatar
AJ
Removed it. See image below. The dome/coil assembly also pops off and is replaceable.
The remaining assembly was press fit into a board that had a 1-5/16" hole with a 1/2" routered roundover. No complex shape or anything, just a 90 degree arc with a .5" radius. I've come to the conclusion this is a prefered way to mount this tweeter, and it sure beats the hell out of countersinking that odd flange shape.
-Zaph|Audio-
Old 8th February 2006, 01:32 PM   #5
Banned
Thanks John,
try to save that gem if you make it to the DST meeting .
AJ
Old 8th February 2006, 10:23 PM   #6
Nice Zaph, I had a little play with some Morel (USA) MDT30s and routered a flare into the wood baffle, then mounted the tweet less its baffle into this.
that D26NC looks very simple to play with though. I may just have to try some different raduis and chamfered faceplates, I just need a measurement mic.
any research into off axis response Vs tweeter face profileHide this!Advertise here!
Improving off-axis response of a 15" alexclaber Multi-Way 24 20th July 2009 04:00 PM
On the hunt for the great off-axis tweeter response Lindell Multi-Way 2 9th March 2009 02:52 AM
On-axis vs. Power Response bunzinthesun Multi-Way 15 12th November 2007 07:12 PM
can one address poor off axis response if many drivers were used tech.knockout Multi-Way 2 26th May 2006 09:12 AM
Looking for Monacor freq response off-axis mgrzemow Multi-Way 0 20th October 2003 12:10 PM
