Does anyone know of any major draw backs of using only one line of Full range drivers in a line array? I plan on building a pair of speakers using 20 3” tang Band drivers coupled with a power sub, and before I invest, I want to make sure I am not going to regret it. So if anyone knows of any draw backs, please share! Thank you!
I've attached some reference material on the type of project you are talking about.
Tang Band Line Array
Jim Griffin's Line Array White Paper
From the driver perspective, the project shown above addresses the strong points and weaknesses of the little Tang Band. From the line source perspective, a thirty-inch line source is a bit small, and you may find that using more drivers in a larger line to be a definite plus. Those issues are covered in Jim Griffin's white paper.
Good Luck on your project
The Ribbon Project
The Ribbon Project
