Howdy
Anyone got any thoughts or experiences with attching a baffle using epoxy or PVA? I'm lacquering and looking for the best union possible. Any advantage to using epoxy over yellow high-bond PVA? Mos |
#2 |
If the baffle and box are both made of wood (natural, or compressed derivatives) I reckon you will do better with PVA. This tends to soak into the wood (being water-based) better than most other adhesives like epoxy etc. The advantages I see here are that the glue line between the two parts will be much thinner as most of the 'substance' of the glue will have sunk into the wood, and there will be a more intimate contact between the two parts. With epoxy, I think the joint will also be a little more 'flexible', as there will ultimately be a thin plastic membrane (effectively) between the joined parts when the glue has set. However, if the fit of the parts is not very good, and some gap-filling is needed, epoxy may well be the better choice as PVA does not bridge gaps so well and the joint can end up 'starved' when the glue fully dries out. PVA actually 'dries out' partly by evaporation and soaking into the substrate, but epoxy remains 'substantially' much the same as when the glue is applied and the joint is put together, and epoxy hardens merely by a chemical reaction. I hope this helps. Regards,
Bob |
#3 |
Bob, my thoughts exactly. If epoxy gives me a non-shrinking or less problematic joint then that's what I should go for. I used epoxy to fix my port in MDF but that's becuase I was gluing plastic which isn't absorbent.
Big advantage to PVA is it's easier to work with, clean up, etc. Mos |
| Epoxy covered crossover?? | Ryder | Multi-Way | 10 | 24th August 2010 12:06 AM |
| Coloring Epoxy? | Zero Cool | Everything Else | 4 | 25th December 2006 09:25 PM |
| Anodized Aluminum and Glue/Epoxy | Bryan | Tubes / Valves | 22 | 18th May 2004 11:24 PM |
| Debond epoxy | Pbassred | Solid State | 6 | 7th April 2004 04:38 AM |
| Epoxy + sand for speakers? | mulebarn | Multi-Way | 13 | 26th February 2004 04:29 AM |
| Page generated in 0.07714 seconds (72.42% PHP - 27.58% MySQL) with 10 queries |
