I'm building a bipolar surround with two side firing Audax TM025F1 tweeters and a front firing Dayton DC130BS-8 Woofer, each having a nominal impedance of 8 ohms. I was planning on wiring the tweeters in series to keep the impedance up for my receivers sake. The woofer has a SPL of 88dB and the tweeter has an SPL of 92 dB. I am planning on putting a -4dB Lpad after the high pass crossover. With the series configuration of my tweeters, am I padding them too much? Should I wire the tweeters in parallel or will that make my impedance too low for my receiver (rated for an 8 ohm speaker) to handle? Thanks in advance for you help
Grant |
| axial surround instead of radial surround | Calvin | Subwoofers | 22 | 13th July 2009 06:46 PM |
| Bipolar capacitor question | DeadSpeaker | Solid State | 7 | 28th April 2008 01:50 AM |
| digital potentiometer bipolar signal question | Leolabs | Solid State | 1 | 30th September 2006 04:40 AM |
| Di/Bipolar Surround Guide | wigginjs | Multi-Way | 3 | 9th August 2004 10:26 AM |
| Question of how to glue driver surround to casket... | stappvargen | Multi-Way | 16 | 13th January 2004 07:05 AM |
| Page generated in 0.06435 seconds (67.71% PHP - 32.29% MySQL) with 10 queries |
