Old 3rd February 2006, 04:21 PM   #1
ermes is offline ermes  Greenland
Default davis 17gklv6m parameter,please help!!
hi,
i'm searchind the t/s parameter of the davis 17gklv6m.
in web there is poor imformation about it.
please help.
b.r.
Old 3rd February 2006, 07:48 PM   #2
Davis acoustics site don't works in mozilla
and parts express specs : Davis 16 GKLV 6 M at partsexpress
you have the specs measured by partsexpress under the "more info" tab
what do you plan to do with this driver ?
Old 3rd February 2006, 07:58 PM   #3
the driver is 17gklv6m not 16....
Old 4th February 2006, 08:29 AM   #4
ooops sorry , yes i understand now why you don't find any parameters , there is no much references about this driver , however i found this, although i don't know what it's worth : http://www.lsv-achenbach.de/listen/davis.htm
although the qts qms and such are very different, the other specs are so similar that i find it weird. The mms especially is a bit lower on the 17 , so it could be good specs, and it could be bad.
is this a reference you actually have at your home ? because if it is, this is not so complicated to measure T/S. If you don't have it , i suspect the driver don't exist or isn't in production anymore.
if you are sure it is, i could contact a shop that is in personnal relation with davis and that surely have a bit of information about it
Old 4th February 2006, 09:34 AM   #5
Originally posted by Nemophyle
[B]ooops sorry , yes i understand now why you don't find any parameters , there is no much references about this driver , however i found this, although i don't know what it's worth : http://www.lsv-achenbach.de/listen/davis.htm
no problem.
thank you indeed for the helpfull link you posted me,it is what i'm searching for.
there are not all parameters but it is better then nothing.
yes the reliability of the parameters of the link are not sure,but is just to keep an approach to the type of speaker.
sorry,
i have cliowin,but not the speaker.......or better : some time ago i've measured the davis: spl,imp and t/s,but now in my data base there are only spl and imp !,not the t/s parameters : probably i've loose they.
the driver isn't in production,like you sad.
i can't measure it because is in the hands of my friend too far from me.
oh,will be so kind from you,thank you.
i wait good news from you (i hope).
b.r.
Davis Driver's Any one used ? jleaman Multi-Way 9 8th April 2006 09:32 AM
looking for Betty Davis Artmaster Music 0 8th July 2004 10:33 AM
Req. What does this parameter mean? stigla Tubes / Valves 9 7th March 2003 07:40 AM
Page generated in 0.06985 seconds (84.90% PHP - 15.10% MySQL) with 10 queries
