Old 1st February 2006, 12:21 PM   #1
Default free Tina ti circuit sim for crossover design
http://focus.ti.com/docs/toolsw/fold...t/tina-ti.html
Hi all,
i've found the above sim very easy to use to model crossovers,
if you represent the drivers by its Re and Le. You'd need a more
advanced driver equivalent model to cope with the impedances
peaks due to fundamental resonances and reflex tuning etc.
/sreten.
Edit : you have include an unconnected op-amp in the circuit
to get it to work, but this doesn't cause you any problems.
Old 1st February 2006, 12:42 PM   #2
Ouroboros's Avatar
TINA is a nice user-friendly SPICE program using the 3F5 engine (I believe). I use the 65 Euro basic version and have no problems. As with any of the easy-to-use SPICE programs around it doesn't provide as much in the way of control and diagnostics as LTSPICE for example, but it's a very nice way of getting into simulation, and (in my opinion at least) is better than any of the versions of Electronics Workbench.
Now build up some simulation models of real loudspeakers and crossovers to load your (virtual) amp designs with!
Old 1st February 2006, 11:10 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Well, you can use speaker workshop and it works just fine for circuit sims. Also the PCD from the FRD consortium.
The simulation from a spice program isn't really any good for loudspeaker design without measured response data and that isn't easy to put into a spice program.
Spice is however very nice for doing circuit sims and getting a basic understanding of how things work.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
TI Tina ctardi Chip Amps 5 17th January 2010 12:47 PM
About Tina and SwCad III simulators gaetan8888 Solid State 0 28th January 2008 09:41 PM
TINA Slow? richie00boy Parts 17 18th March 2007 06:02 PM
How to design Crossover circuit of the loudspeaker using accuton ceramic driver unit? kevinlin1013 Multi-Way 9 20th August 2005 09:47 PM
Free crossover software? squidbait Multi-Way 9 22nd March 2004 03:37 AM
Page generated in 0.07452 seconds (68.63% PHP - 31.37% MySQL) with 10 queries
