open baffle drivers?
Old 1st February 2006, 08:18 AM   #1
SemperFi is offline SemperFi  Wake Island
Default open baffle drivers?
What parameters are important to look for when selcting drivers for open baffles?
Old 1st February 2006, 08:34 AM   #2
el`Ol is offline el`Ol  Germany
Many people use drivers with high Qts (>0.6) and small baffles. Even high-Qts drivers will only bring bass when the baffles are large enough. For a dipole-FAST concept with sealed/ported bass you are free to choose.
Old 1st February 2006, 01:13 PM   #3
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
As long as we donīt know what kind of driver you mean (woofer, mid, treble) itīs hard to give any valid advice. Differences are too big between those regions IMHO.
www.dipolplus.de
Old 2nd February 2006, 06:02 AM   #4
Landroval is offline Landroval  Finland
What was this again?
Old 2nd February 2006, 08:23 AM   #5
FAST refers to fullrange speaker plus bass, usually with aubout 200Hz crossover. I didn`t realize this thread is in the "loudspeaker", not "fullrange" forum. You even see Lowthers, AERs and Fostexes in dipoles. The Prometheus, maybe the most successful dipole kit also has a low-Qts wideranger.
However, if you have the size for big OBs you will have an uncompressed bass you don`t get with boxes.
open baffle drivers?Hide this!Advertise here!
Best drivers for Open Baffle pforeman Full Range 87 6th May 2014 09:32 AM
Open baffle drivers and FirstWatt amps. khundude Pass Labs 1 16th June 2008 04:11 AM
Open-Baffle dipoles...a heresy to pair PA drivers w/ home drivers? thadman Multi-Way 7 11th November 2006 10:11 PM
Open baffle With cheap, large, low Fs car drivers bigwill Subwoofers 25 4th June 2006 01:21 PM
Open Baffle Line Array - using cheap drivers giambi77 Multi-Way 4 26th January 2004 10:29 PM
Copyright ©1999-2017 diyAudio
