I have previously finished cabinets by sanding to about 600grit and applying danish oil, this can look stunning but it gives a light amber tint to the wood which darkens over time, is there an oil that doesn't age as severely and doesn't give the wood an amber tint. I have some Beech that once sanded is a very good match for the current furnature, I don't want to oil it and find it goes darker. Is there another finish available which gives a satin like finish which is resistant to liquid and occasional knocks.
#2 |
could you do a lacquer? just a clear, semi-gloss of flat brush-on lacquer? it wont change the look of the wood really, it just gives it a wet look, like the danish oil does. and it shouldnt darken over time. and of course it will protect the wood.
#3 |
All wood darkens with exposure to the air and sunlight. The way this is prevented on modern commercial products is to use a UV blocking lacquer.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| dark tinted material for front panel display window | grayson | Parts | 5 | 12th June 2008 12:03 AM |
| wood finish: linseed oil + turpentine ? | JC Fardo | Multi-Way | 10 | 20th May 2005 04:03 PM |
| Wood finish | fireman | Multi-Way | 15 | 25th October 2004 07:06 PM |
| A wood finish question | kneadle | Multi-Way | 19 | 17th July 2003 03:51 PM |
| Page generated in 0.08844 seconds (69.01% PHP - 30.99% MySQL) with 10 queries |
