Old 31st January 2006, 08:56 PM   #1
gfinlayson's Avatar
Default Big spade connectors?
Does anyone know where I can find BIG spade connectors? I got two pairs of these from Wilmslow without realising how big they are. The threaded shaft under the knurled nut is 13 mm diameter. Does anyone know if there are spades made big enough to fit?
Old 31st January 2006, 10:01 PM   #2
afaa is offline afaa  United States
Send a message via ICQ to afaa Send a message via AIM to afaa Send a message via MSN to afaa Send a message via Yahoo to afaa
Default IXOS 207 Spades
http://www.accessories4less.com/cgi-bin/item/IXOS207
I have these and the opening is huge. I don't have it with me at the moment but the opening is approx about 1/2 inch in diameter.
Old 31st January 2006, 10:18 PM   #3
gfinlayson's Avatar
Excellent! Google has turned up a few places in the UK that sell them..I'll give them a try. Thanks.
Old 1st February 2006, 03:18 AM   #4
poobah is offline poobah  United States
poobah's Avatar
gfinlayson,
Why not use the the cross hole under the knurled nut as intended?
You could solder Small piece of copper tube on to the end of your speakers cables.
Or you could use these. I sure you could find these in the UK.
I know you can find 13mm ring terminals... I have never seen a fork terminal this large.
Old 1st February 2006, 06:37 AM   #5
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Locking banana pluges would also be good.
Hear the real thing!
Old 1st February 2006, 08:02 AM   #6
gfinlayson's Avatar
Thanks Poobah. I did consider using M12 ring terminals, M12 fork terminals or cable ferrules, but even buying via my work's discounted corporate account, I'd still have to buy a minimum of 100, which works out to anywhere from £30 to £70.
Old 1st February 2006, 02:13 PM   #7
poobah's Avatar
Hmmmmm............
Source for .110", 26-20AWG Female Spade Connectors (for speakers & such) EchoWars Parts 0 4th December 2008 06:25 AM
solder or spade? dayking79 Multi-Way 14 14th September 2008 06:16 PM
Needed Heavy Duty Spade Terminal Connectors speedemon Parts 2 13th February 2007 01:13 AM
banana or spade for 12-ga wire Alex Barnett Parts 4 29th December 2006 04:48 AM
Lug or spade - that's the question peranders Parts 12 11th January 2004 05:23 AM
Page generated in 0.08527 seconds (78.73% PHP - 21.27% MySQL) with 10 queries
